| General TDI Discussion - MKIII-A3/B4 TDIs This is a general discussion about MKIII-A3/MkIII Jetta/Golf (<99.5) and B4 Passats (96,97) TDI's. Non TDI related postings will be moved or removed. |
March 1st, 2005, 10:17
#1
Revised B4 MFA conversion article
March 1st, 2005, 17:11
#2
You're my hero Chris!!!!!!!!
I also wanted to get the original tach back, bought another cluster to do the swap...
I'll read your revised DIY with great interest!
March 1st, 2005, 17:47
#3
Awesome!!!
By the way, you refer to Palo Alto Speedometers...any idea if they would do a cluster conversion?
March 2nd, 2005, 03:40
#4
This is EXACTLY what I was hoping to do! Now that this writeup is out, all I need is to source the remaining parts! I have a GLX cluster 3AO 919 035 H, I forgot what year GLX it came out of. The p/n is different from the discontinued one you mention, however it does have the MFA and is buit by Motometer. Should I be concerned?
March 2nd, 2005, 05:17
#5
Re: Revised B4 MFA conversion article
Thank you Chris!
March 2nd, 2005, 06:34
#6
Awesome!!!
Unfortuately, no they won't.
March 2nd, 2005, 06:36
#7
It shouldn't be a problem. It may an automatic cluster.
March 2nd, 2005, 12:22
#8
Thanks. It does not have the gear selection window. I'm looking forward to picking up the remaining parts.
March 3rd, 2005, 19:50
#9
Any A3/B4 cluster can be reprogrammed for country code and # of cylinders, I did this with MFA on my A3 Jetta using VR6 cluster, its just a matter of small change in the software, its pretty simple.
March 3rd, 2005, 20:15
#10
Could you elaborate please?
March 3rd, 2005, 20:48
#11
All data like country code is implemented in the software in HEX code, for example when you read the chip and look in to the code, US is 02 CAN is 20 UK is 49 and EU is 48, this code is related to the clock (12/24) and service reminder (only EU and UK have this when recoded) then if you look further you will notice number of cylinders (4 cyl is 80, when 6 cyl is C0, and the similar thing with impulse # 6056 is for VR6 in hex is 17A8)so if you compare data from TDI cluster and VR6 MFA you will notice how its done.
March 4th, 2005, 06:32
#12
Could you elaborate more please? Read the chip?
March 4th, 2005, 07:32
#13
Do you need a HEX-COM interface to read the cluster? A KEY-COM interface won't read it
March 4th, 2005, 09:05
#14
Inside this cluster is chip 93C56, to read this programmer is needed, VAG won’t work
March 13th, 2005, 19:58
#15
I am confused why a pulse frequency adaptor would be necessary for a GLS cluster as it also has four cylinders. I assume because of different spacing on the tach face?
| Thread Tools |
Search this Thread |
