Old October 11th, 2015, 09:34   #331
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
Evildad-
Don't confuse the Castrol Edge you can buy at common parts stores with that having the 507 rating. I believe this can only be ordered on line or purchased at VW/Audi dealers.
-tom
autos: 15 Volvo V60, 14 BMW 535d xDrive
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old December 20th, 2015, 08:39   #332
raybo
Fuel Economy: 2001 Golf (SOLD 11/15/15): 45 MPG avg mostly highway; JSW high 30's around town
It's always good to compare oil specs with the Lubrizol tool: https://www.lubrizol.com/apps/relperftool/pc.html
SOLD 11/15/15: 2001 Golf GLS 5-Speed Reflex Silver 391K
GOT 11/15/15: 2016 GSW S 1.8 TSI 5-speed Reflex Silver
2010 JSW DSG White Gold Metallic/Corn Silk 105K | Pano | Liqui Moly Top Tec 4200 as of 50K | Continental PureContact | built 11/09 (hers) HPFP disintegrated 12/14 - entire fuel system repaired by VWoA Jan 2015 at 93K miles
raybo is offline   Reply With Quote
Old January 2nd, 2016, 13:43   #333
Rodmiser
Fuel Economy: sorry last tank 44.2 MPG
Default Bobistheoilguy
IF YOU CAN'T FIND THE OIL YOU NEED ? Just run it with 1940 motor oil. Then do a oil change with the right oil ok...asp
Rodmiser is offline   Reply With Quote
Old October 26th, 2017, 18:38   #334
Rodmiser
Default 507
Schaeffer 8008 Advanced European Performance Mid SAPS SAE 5W-30 - 12 Quart Case
Old October 27th, 2017, 07:04   #335
SilverGhost
SilverGhost's Avatar
So I was just reading on VW technician FB page about oil specs - turns out VW dropped the 505.01 (that was superseded to 5w30) and just made 507.00 the spec for TDI-PD engines.
Jason
SilverGhost is offline   Reply With Quote
Old October 29th, 2017, 12:40   #336
TooSlick
TDI(s): Audi 100S
Well the VW 505.01 oils never impressed us very much. Folks have been getting much better wear numbers by using the latest, HD diesel oil Spec (currently "CK-4/SN"), in PD motors calling for VW 502.00/505.01. I have had fine results using the VW Spec stuff in VW & Audi gas engines that call for a VW 502.00, gas engine formulation.
TS
TooSlick is offline   Reply With Quote
Old November 1st, 2017, 16:02   #337
donDavide
donDavide's Avatar
Fuel Economy: 51/45/40
Jason
I thought some of the 507 bottles say not for PD
2003 Jetta GLS TDi TTbushings
2005 Passat GLS TDI Wagon Stone Henge Gray
2007 Jeep Grand Cherokee CRD
donDavide is offline   Reply With Quote
Old November 21st, 2017, 19:06   #338
donDavide
donDavide's Avatar
TS
CK4 are supposed to be safe for trucks with DPF, But I can't find sulfated ash, I wonder how it compares to 507.00 and MB 229.51?
Old November 29th, 2017, 21:40   #339
tikal
Fuel Economy: 37 MPG (~ 45% city)
According to these API CK-4 Amsoil flavors the sulfated ash is between 0.91% and 1%:
https://www.amsoil.com/lit/databulletins/g3467.pdf
Compare that to the 0.6% for the Mobil 1 ESP Formula 5W-30:
https://www.mobil.com/english-us/pas...p-formula-5w30
tikal is offline   Reply With Quote
Old November 15th, 2018, 18:23   #340
miltoncf
Default Should a 93% oil filter last 10k miles?
https://www.mobil.com/English-US/Pas...bil-1-ESP-5W30
Yet on this page for the same oil (but w/out "formula") it's 0.8%, with slightly lower Pour Point, Density, and Viscosity at 100 C. On the latest product-specs-guide only two oils have "Formula" in their name: Formula M 5W-40 for Mercedes 229.3/5 and ESP Formula 0W-40 for GM dexos2.
But the former may be what a coworker w/an Audi A3 was using years ago. He said that the car was less sluggish than w/ 5W-40 when new. My 2003 Jetta was as well, but using Mobil 1 Extended Performance, and changing it well before 15,000 miles as it seemed that I shouldn't be pushing the lighter grade to the limit when the stated preference in the manual is 5W-40 (and the filter wasn't rated at 99%). I'm now using a 93% filter w/Mobil's High Mileage 5W-30 (non-EP) that likewise has ACEA approvals B1 & B5. BTW, should a 93% filter last 10k miles?
miltoncf is offline   Reply With Quote
Old November 15th, 2018, 20:08   #341
turbobrick240
turbobrick240's Avatar
There are much better diesel rated oils out there that aren't any more expensive (the 0w-40 M1 European car 505 spec comes to mind). That B1/B5 stuff is pretty weak sauce for a tdi, imo. I'd use it in my ford/IH 7.3 w/ 4 gallon capacity if someone gave me a bunch for free. But not in the tdi.
Old November 16th, 2018, 17:57   #342
tditom
[URL]... I'm now using a 93% filter w/Mobil's High Mileage 5W-30 (non-EP) that likewise has ACEA approvals B1 & B5. BTW, should a 93% filter last 10k miles?
If this oil isn't rated for diesel, then you shouldn't use it.
Use any 5W40 for an ALH. I've never seen one that isn't appropriate for that engine.
As for filters, I don't remember what the Mahle/Mann/Hengst cartridges were rated, but 93% sounds pretty low.
-tom
Old December 8th, 2018, 20:47   #343
DarthJe5us
TDI(s): 1.9 TDI ASZ
I am writing in hopes that you can reply to me. I was looking at the castrol oil selector and for my car it said i should get castrol edge 5w-30. My car is a 2002 VW Bora 1.9 TDI ASZ 131 horsepower. Tonight i was told i should not have used that in my engine. Did i make a big mistake and should i change the oil in my car again?
DarthJe5us is offline   Reply With Quote
Page generated in 0.18682 seconds with 9 queries
[Output: 116.71 Kb. compressed to 97.77 Kb. by saving 18.94 Kb. (16.22%)]
