Old February 15th, 2005, 07:03   #1
AlanTDI
Fuel Economy: lost track
Default translation needed:ABGAS WERKSTATT!
I got this message on my low pixel cluster?
any ideas?
Sorry about the size of image
AlanTDI is offline   Reply With Quote
Old February 15th, 2005, 08:17   #2
cattlerepairman
cattlerepairman's Avatar
Fuel Economy: 8.4 l/100 km at 60/40 hwy/city
Abgas means exhaust (literally). However, it refers to emissions.
Werkstatt is a garage/dealership.
Time to hook up VAG COM!
cattlerepairman is offline   Reply With Quote
Old February 15th, 2005, 09:04   #3
moondawg
moondawg's Avatar
Fuel Economy: Best: 52.33 Worst: about 39 Avg: 48
You have a glow plug circuit or coolant temp sensor code. betcha.
(I have both of these codes, and don't know which one is causing this.) I'm guessing the coolant temp one, since the ECU won't know how to adjust the timing.
anywho. hook up VAG-COM!
moondawg
moondawg is offline   Reply With Quote
Old February 15th, 2005, 09:41   #4
thelifeof
Default Re: translation needed:ABGAS WERKSTATT!
In case your car starts to speak more German, you can use any of these free online translators.
http://www.freetranslation.com/index.htm
http://www.translate.ru/eng/text.asp
http://translator.dictionary.com/text.html
thelifeof is offline   Reply With Quote
Old February 15th, 2005, 09:53   #5
AlanTDI
My cluster/car speaks a lot of german . I should teach it english. Considering it lives in the USA . (New Yark) I think i'll have to give it a good going over with the vag-com .
Thanks, i'll get my vag-com hooked up.
I've have been seeing a number of coolent sensors problems talked about on the forums. Hopefully thats the extent of it.
Alan
Old February 15th, 2005, 13:13   #6
AlanTDI
Hi:
Hooked up VAG-COM
this is the code:
17057 Cylinder 3 Glow plug
electrical fault
P0673-35-10 intermittent
Do I have to replace the glow plugs or the harness?
I sprayed the contacts with contact cleaner, but fault still returns.
Thanks,
Alan
Old February 15th, 2005, 13:54   #7
DLCTDI
check glow plug #3 resistance to ground. If it is 1.5 ohms or lower then it is OK, if it is higher, then replace it.
DLCTDI is offline   Reply With Quote
Old February 15th, 2005, 15:14   #8
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
On some cars the cylinders are counted backwards by the ECU...
So check the resistance of # 2 also... (and clean the contact there while you're at it...)
Yuri.
ymz is offline   Reply With Quote
Page generated in 0.15074 seconds with 9 queries
[Output: 79.17 Kb. compressed to 67.87 Kb. by saving 11.29 Kb. (14.26%)]
