millere5815
I got to put my car on a dyno today. Some people are guessing that the numbers were not accurate, based on my upgrades. I'd like to get your opinions if I could.
Upgrades:
Vnt17 turbo
Dlc 1019 nozzles
11mm pump
Malone stage 4 tune, 23psi
Upgraded intercooler
The dyno was unable to register engine rpm, so I used two equation. The first was to get my engine rpm from my speed. I just used an app on my phone to do it for me based on drive ratio, tire size, and a given speed. To find the torque, I used torque = hp x 5252 / engine rpm.
Dyno reported 155hp at 2250rpm
Math calculated 360 torque at the same rpm.
I have yet to get a dyno print.
Some people are claiming that isn't possible with my setup. Opinions?
After receiving a copy of the dyno sheet, I realize that I was wrong about my power outputs.
156hp at about 3000RPM
max torque was 298 at 2450 RPM
Upgrades:
Vnt17 turbo
Dlc 1019 nozzles
11mm pump
