Faygo1.9
Hello little introduction, here is my 1.9 tdi I picked up stock for $1000 3 months ago I ended up getting a custom tune from Jeff and upgraded my injectors, pd 150 from Uk eBay for $150 shipped low mileage. I ended up snapping the exhaust wheel off the turbo rebuilt the engine bigger and better at that point why go stock turbo so I said go big or go home made my own oil lines with -4 an oil supply -10 oil drain. Originally went with a Holset h1c I was having issues with it I can’t get it to build more than 2 psi I believe it has plenty of fueling, that was on my stock turbo tune with pd150 injectors mapped in Jeff told me to do some data logs with that tune and the results weren’t that good only made 2 psi not sure what the issue was. So I ended up swapping it for a different Holset with a smaller exhaust side hx40. That seems to be doing better still waiting for a revised tune with maf delete and smart actuator delete. Not sure how much boost this setup is making but it definitely spools higher than the other turbo. Any suggestions? I’ve checked for exhaust leaks boost leaks, I put a restrictor in the oil feed.
