Old December 15th, 2017, 23:24   #16
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Originally Posted by rbptdi View Post
Sure seems like a weird design. That bearing is trying to punch through that bushing with every excursion.
The bushing is rubber, the bearing metal. Isn't that a recipe or rapid wear?
Do you guys grease the surfaces at all? Anything I can do to reduce wear-rate?
Wouldn't it be better to have a lining inside the bushing, where the bearing hits, to distribute forces and protect the rubber? Maybe nylon or teflon?
The bearing looks broken as I see the small ball bearings exposed. The bearing is a smooth shell of some plastic looking material. Here is a close up from idparts.com. It goes right under the hard rubber bushing and on top of the metal plate that holds the coil spring in place. A shouldered nut holds the bushing to the bearing, and then to the plate.
Look around 13:30 onward in this video for how it goes together.
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old December 16th, 2017, 08:17   #17
rbptdi
Fuel Economy: 45-47mpg, pretty much every tank
Yes, I studied the schematic, I know how it goes together.
Took the top 2 nuts off, driver's side. The top nut is correct, bottom is NOT.
Looks almost like a nylon lock nut from the hardware store. No shoulder. Grrr.
rbptdi is offline   Reply With Quote
Old December 16th, 2017, 08:43   #18
Blacktree
Fuel Economy: 44-45 mpg (mostly city)
Originally Posted by oilhammer View Post
Yes, they started doing it that way way back with the A2 cars in 1985. A3s and A4s are the same way. Sometimes the mount sticks in the body when you lift the car up, sometimes it drops out. When they drop out is when the confusion starts, if you did not understand that was normal for them.
Thanks for the explanation. I thought there was something wrong with my car. Heh...
Blacktree is offline   Reply With Quote
Old December 16th, 2017, 09:02   #19
rbptdi
Old bushing pretty squished.
Old December 16th, 2017, 09:24   #20
slevang
TDI(s): 2002 NB TDI
One shouldered nut and one non-shouldered is correct, but if I am understanding your description it sounds like they were put on in the wrong order. See here for photos:
http://www.fixmyvw.com/front-strut-b...fast-and-easy/
It is probably important that the lower nut be the shouldered one, so it supports the full surface of the bearing. I think this is why the upper case of your bearing looks busted in the first photo.
Your springs are losing their coating but they can go a while like that, so you could put it off until spring.
slevang is offline   Reply With Quote
Old December 16th, 2017, 09:46   #21
rbptdi
Correct. PO had shoulder nut on top.
Back together. Much better. Note 2" lift spacer.
Bearing sits like a washer on top of the strut shaft shoulder.
How are you supposed to torque these things to 44lbs? Can't hold the 7mm hex still with any kind of torque wrench on either nut...
Old December 16th, 2017, 09:57   #22
rbptdi
Apparently the passenger's side is harder b/c the frame gets in the way. Any tips on that?
Old December 16th, 2017, 10:02   #23
rbptdi
BTW, the shoulder nut fits just fine through the bushing (new or old).
No need to swap nuts per DIY linked above.
Old December 16th, 2017, 11:10   #24
rbptdi
Axle hits frame. Why not just pry down on the spring a bit? Just need to woodgie that old bushing out...
Old December 16th, 2017, 11:35   #25
indysoto
indysoto's Avatar
[QUOTE=rbptdi;5360135]Axle hits frame. Why not just pry down on the spring a bit? Just need to woodgie that old bushing out...
Dunno if my remembery is serving me right but either turn wheels all the way to the left and slip the cv out the hub or take the front and rear inner a arm bolts out give you more room to take it out.
2000 a4,G60 single mass, KYB AGX(replaced 2x :|), 215/65/r16's...
2004 BEW Wagon w/ Meyerhoff AutoHaus Runonbeer Sticker
indysoto is offline   Reply With Quote
Old December 16th, 2017, 11:52   #26
slevang
TDI(s): 2002 NB TDI
That's where spring compressors come in handy. If you can't manage to slip it out or get compressors, some people drop the subframe just a 1/2" or so which gives clearance, as an alternative to messing with the axle.
I don't think moving the control arm gets you anything, and brings in the risk of breaking off the captive nut inside the subframe.
Old December 16th, 2017, 11:56   #27
rbptdi
I had good luck just prying on the top of the spring with a 2x3 to get the old bushing out. Trying to get the new one back in now. Stand by.
Old December 16th, 2017, 12:55   #28
rbptdi
All set. Good as new. Tight and quiet. Too bad the inspection place closed at 1pm.
No 'shredded bearings' at all, btw. Just a little twisted rubber. Everything was normal, but worn, with nuts flipped.
The 2x3 pry worked for me, but only b/c I had the lift kit. YMMV
Thanks for all the help, crew!
Old December 16th, 2017, 12:55   #29
rbptdi
Only problem is, now I can hear the rear mounts.
Old December 16th, 2017, 22:03   #30
UhOh
UhOh's Avatar
Excellent work!
UhOh is offline   Reply With Quote
B4 strut issue joshuare VW MKIII-A3/B4 TDIs 4 March 1st, 2015 13:46
Strut Replacement Issue shaneb75 TDI 101 4 August 29th, 2009 17:14
Strut mount issue dremd TDI 101 4 September 13th, 2008 19:49
Interesting strut issue BruhahaX VW MKIV-A4 TDIs (VE and PD) 9 August 8th, 2005 08:12
Front Strut Tie Bar Tightens Up Front End & Improves Handling Turbo Steve Upgrades (non TDI Engine related) 25 December 11th, 2000 17:24
Page generated in 0.36131 seconds with 13 queries
[Output: 124.34 Kb. compressed to 103.69 Kb. by saving 20.66 Kb. (16.61%)]
