ThE_gOg
hi
turbo wne't on my wifes car so,
a hybrid rebuild was cheaper than an excahnge unit, so i had a hybrid rebuild on it.
the outlet then changed size so to get the red/orange hose on the turbo outlet to fit i had to remove the coupling from the end, and push the hose over the end of the outlet.
the car drives fine etc, i'm just a bit worried now,that the coupling that i've removed looks like alot of engineerings gone into it, is it ok to get rid of it??
is it just to give a bit of rigidity to the pipe? or does it serve a different purpose??
thanks for your time
Chris
Chris
