MichiganTDIguy
Yeah I had to replace the relay but how do I know if my pump is bad or the relay?
What is gtgGTG in Grand Rapids on October 18th if no luck by then drag it there and it will be swarmed by TDI'ers
Thank you Abacus,Is the solenoid clicking when you apply power to it, either by the key switch or externally?
Does your glow plug light come on when you turn the key?
Do you have power (12V) at the top of the injection pump solenoid for a second when you turn the key? You will need help for this since the power goes off if the car is not cranking and is not running.
Answer these and we can go from there.
