I've already arrived at that conclusion by myself. So save your fingers if you feel the need to spend your valuable time chastising me
2000 Beetle TDI 5 speed 275,000 miles.
I needed to adjust the odometer by adding 2,000 miles to it. I have a local friend who is a locksmith and has vag-com in order to read pin codes for programming keys.
I borrowed his vag-com and tried to do the adjustment.
It showed current value as -1 miles, which I thought a little strange. I added the new mileage. When I got through, the mileage hadn't changed, but the speedometer, tach, and gas gauge weren't functioning, and the oil light was blinking. The odometer was functioning however. After putting around with it some more, i managed to get the odometer to read all 9's and not work. The trip odometer still works however.
Any thoughts?
Any thoughts?
