cwspen
Hi All...
I had a VERY bad shake when braking for the last year or so. I assumed "I put on cheap rotors last brake job, they must be warped."
New pads and rotors from VW, my labour (done lots of brakes) were put on approximately 7,000 km ago.
Immediately after changing them the braking was smooth and beautiful. I thought I detected a slight "shake" (during all phases of driving) but thought that might be my mind playing tricks on me. Had the tires balanced since I bought them used, shake seemed to improve.
7,000 km later and it's starting to be very noticeable when braking again. Noticeable at other times too, but worst when braking.
So, what could lead to these symptoms?
My car is a 2001 with approx 250,000 km on it. With the exception of brakes, oil changes, & timing belts it's all original (suspension, bushings, bearings, etc.)
So what steps can I take to figure out exactly what the problem is?
I'd hate to just keep throwing parts at it until I find the culprit, but don't want to replace everything all at once unnecessarily too.
