treedweller
I just dropped wife off in houston (02 NB)for her vacation and was loading the CD's for the return trip. I wasn't sure which side was up. Loaded disks, left hatch and door open to check if it was right. Monsoon msg: check [cartridge]. Turned disks over, same msg. turned 1/2 of disks over, same msg. Put them back to what I thought was up, closed hatch, same msg. Eventually I got it to work when the hatch and doors were all closed before I turned the key in the ignition.
The question is: do I have to close all doors before the CD changer will work, or is this an intermittent problem with the hardware that finally worked itself out? No probs with any disks on the way home.
Keith
Keith
