Gerich@apex-tuning
Ok. I use this term alot. "Its not my first day" I love working on tdis, own several myself and have seen so many different things cause a low power situation but this one has me stumped.
Either myself or one of the shops it went to before it was brought to us has installed the following in an attempt to fix the issue:
There are no codes.
All vacuum lines tested, verified they are going to the right place and in good condition.
swapped in a new maf. Both old and new the readings drop to 280 as rpms rise for actual maf reading no matter what requested maf readings are. I am sure this is part of the issue but I have checked all the inlet piping, charge piping, intercooler, etc and have not found any leaks or obstruction. We also swapped on a downpipe with the cat removed just to make sure we didnt have a clogged cat.
The turbo was replaced because we could barely spin the impeller on the inlet side however that made no change even though the only code stored was a underboost code which has not returned but the car is still low on power.
I put in egr block off plates to eliminate a possible bleed off in the egr system.
I swapped in a known good N75 solenoid. Logging vagcom the duty cycle will stay at 24.7% even under WOT instead of cycling up to 70ish % and tapering off from there. If you unplug the maf duty cycle rises but not very quickly and it reaches requested boost but still no power. Lots of black smoke with maf unplugged and none plugged in. I swapped in a brand new maf and same results both plugged in and unplugged.
I have checked the air filter, air filter housing and "snorkel" for obstruction.
The fuel filter was replaced within the past few months according to the customer and looks brand new from the outside and the filter media inside is very clean.
The intake manifold was cleaned about 6mos ago and doesnt appear to have any substantial buildup. I very thin light coating of carbon on the inside but nothing that would cause a restriction
I had a spare immo defeated ecu for a personal project that I installed and still no change.
At this point the issue seems to revolve around a restriction limiting airflow at the maf which in turn is causing the ecu not to change n75 duty cycle and is making for a very slow car.
If anyone can shed some light on what I am overlooking or has a suggestion for a mvb I have not mentioned to look at please chime in.
Ive been working on tdis for years and this one has me stumped like no other so please feel free to say "hey stupid you forgot to check______! so I can fix this car and wear my dunce cap with pride for a few days.
Cheers.
There are no codes.
Cheers.
