Go Back   TDIClub Forums > FAQs (Frequently Asked Questions) > TDI Power Enhancements
TDI Power Enhancements Archives on TDI Power Enhancement related items.
Old May 26th, 2004, 09:46   #61
fatdubsfatman
Default POST YOUR DYNOS
some pretty impressive numbers.
fatdubsfatman is offline   Reply With Quote
Old May 30th, 2004, 04:29   #62
Miguel_Spain
Fuel Economy: 8.5/6.3/3.7
Hi, Im Spanish owner of a Seat Cordoba TDi 90cvs (AHU) with Garret GT15 turbo.
Actually, I have a strong version of an Upsolute chip and all mufflers were removed.
Miguel_Spain is offline   Reply With Quote
Old September 30th, 2004, 07:16   #63
Smog
Smog's Avatar
here is mine :
PD150 turbo
0.216mm nozzles (my products)
Rocketchip 4.0
12mm pump conversion kit (my products)
correction factor of 1.015 on a TAT MAHA dyno
the supreme insult : the car is converted for veggie oil BUT was on diesel for the dyno
Smog is offline   Reply With Quote
Old September 30th, 2004, 08:21   #64
Davin
bleh... noticed the other thread... moving my post there...
Davin is offline   Reply With Quote
Old October 25th, 2004, 08:22   #65
TurbeinDeizle
Fuel Economy: 65.34/54.2/45.2
Yes, there IS a difference in Dynos.
Dynojet does not have a method to measure HP or Torque, as does the Land & Sea dyno, as previously mentioned.
Dynojet calculates HP & Torque based on a known roller mass/inertia, and acceleration rate.
Land & Sea uses a torque arm & full-wave strain gauge to actually measure Torque.
In order to be apples-apples when comparing the Dynojet with a Land & Sea, have the Land & Sea operator set the Driveline loss value at 15%. Dynojet uses a 15% driveline in their HP calculations, and using the 15% driveline loss in a L&S dyno will provide HP & Torque numbers within 1% of one-another.
I'll post my 02 Jetta TDI's HP & Torque numbers as soon as possible, but will need to convert them to PDF format first.
Best HP/Torque to date: 179.4HP / 354Ft-Lbs at the wheels (propane turned up), using our Land & Sea Dyno with driveline loss set to 15%.
Hope this help to clear up the dyno variation issue...
Tom
TurbeinDeizle is offline   Reply With Quote
Old October 25th, 2004, 08:44   #66
Smog
Smog's Avatar
you don't need to set a driveline loss for hp/torque at the wheels....
Old October 29th, 2004, 11:54   #67
TurbeinDeizle
"you don't need to set a driveline loss for hp/torque at the wheels...."
Yes, you do, if you are testing your car on a dyno with a Torque Arm/Strain Gauge, and you want to compare your car's output on a DynoJet dyno....
Tom
Old October 29th, 2004, 12:09   #68
Smog
Smog's Avatar
Tom
so it's not wheelhp...
there's no drivetrain loss when you're talking about whp
and lb.ft is a fixed mesure, it shouln't vary from a dyno to another when taken at the wheels
my car made 172whp but 194bhp (flywheel hp is whp + driveline loss)
Old November 24th, 2004, 05:01   #69
TDIfreak
http://pics.tdiclub.com/data/532/667...20_iso-med.JPG
TDI-R from Seat? No, it's my daily driver.
TDIfreak is offline   Reply With Quote
Old November 24th, 2004, 05:33   #70
TDIfreak
http://pics.tdiclub.com/data/534/667...-paper-med.JPG
My friend's 215 hp Golf.
Comparison of Race520 vs. PP502 as a bonus.
Old December 1st, 2004, 11:20   #71
Oldman
WOW must be a ride! bout 20 HP and look at that HUGE fat massive torque gain. I hope this is a 6 speed?
Oldman is offline   Reply With Quote
Old December 1st, 2004, 12:18   #72
TDIfreak
The pp502 vs. Race520 hp difference is even more, 27 hp.
Last time I heard, the 5 speed is hanging there ok.
Old December 4th, 2004, 15:07   #73
Sootman
Sootman's Avatar
Fuel Economy: 30 +/- MPG
Ok, on a Land and Sea dyno here are my latest numbers. This includes a PD 150 turbo, Kermas' PP764 injectors and finally Jeff's RC 4 chip along with an 11mm pump. Beat my expectations 176.3 hp and 344.2 ft/lbs
Now if I'm supposed to adjust this (+15%) when compairing to a Dyno Jet Dyno I'd have some serious number...from 176.3 to 202.75 hp and 344.2 to 395.75 ft/lbs
Either way the thing ROCKS. Talk about linear power and torque, it's great!!
Sootman is offline   Reply With Quote
Old December 4th, 2004, 15:28   #74
KERMA
KERMA's Avatar
What correction factor? It's probably not too much because you are close to sea level, but still be nice to know.
I see at the bottom it says "standard" correction method, do you have any info about that?
KERMA is offline   Reply With Quote
Old December 4th, 2004, 15:36   #75
Sootman
Sootman's Avatar
The "correction factor" is kind of a joke, to me at least...although apparently not everyone thinks so. There seems to be a bit of controversy about the percentage of difference between assorted dynos out there. I'm sure there is a difference between them, but really the only way to be fair in my opinion would be to use the same dyno on the same day, with the same temperature etc. Even then people no doubt would ***** about something. Bottom line for me is that I am VERY happy with these numbers. And extrodinarily happy with the curvers of both torque and hp.
Page generated in 0.35116 seconds with 10 queries
[Output: 119.90 Kb. compressed to 99.70 Kb. by saving 20.20 Kb. (16.85%)]
