Glow plugs work all year round, despite the persistent myth.
However, the PREglow period varies, and is not very aggressive. In any event, the glow system is always monitored by the ECU, so if there is an issue with it, you'll have a DTC, and the MIL will be shining happily in your face.
So let's rephrase this, since all too often the glow system is blamed for something it has no part in: the car is hard to start cold. So, if you have no glow related DTCs, then we already know the glow system is OK. But, we do not know if the ECU is getting the correct info to properly use it. Coolant temp is the main input here. Verify this value with a scan tool. You can also look at preglow parameters, but that isn't really necessary.
Next I would look for things like loss of fuel prime (leaking pump, thermo-tee, etc.), poor timing (M&P belt install, etc.) or in some cases just a sick engine.
Oh, back to plugs though... not usually an issue on the ALH but the WRONG plugs can cause problems too. And may not ever show any DTCs if they are all the same. This is more of a PD thing, though.
Also, often slow cranking gets overlooked. Worn out starter, weak/wrong battery, poor connections, etc.
