jbeall
Hi All,
I've been thinking about a diesel Jetta wagon for a little while now. I can't afford one with low miles, but the word from the folks I've talked to is that these diesel Jettas will last forever, if taken care of. I found one less than two hours from me that might be a good fit:
http://washingtondc.craigslist.org/mld/cto/3361177135.html
I'm interested in some feedback from folks that have actually owned these diesel Jettas. Do they really last to 300,000+ miles on the original engine? Is any savings in fuel economy eaten up by higher maintenance cost on these Jettas? Am I crazy to consider buying a Jetta with almost 150,000 miles?
I also hear that these auto transmissions tend to die sooner or later. I've been looking for prices on replacing a transmission but can't find any so far. Also, is it likely I could get a standard transmission put in to replace a dead auto transmission? Or is that something that only "enthusiasts" who are doing it themselves tend to do?
I got a spreadsheet from the seller with the following service records. I also bought the autocheck report and it came back clean.
2003 Jetta TDI wagon - 10/28/12
delivery 9/30/2002
Fitzgerald 2/26/2003 4697 oil change
137.96 Fitzgerald 5/28/2003 9366 10K service
49.18 Fitzgerald 6/30/2003 10325 vent, bumper
0.00 Fitzgerald 11/10/2003 16925 oil change
154.76 Mr. Tire 2/28/2004 1 michelin tire
Fitzgerald 3/2/2004 23804 coupon service
338.63 Fitzgerald 8/19/2004 34369 30K, oil
0.00 Fitzgerald 9/17/2004 35930 stereo speaker
394.53 Fitzgerald 1/25/2005 43292 oil change
0.00 Fitzgerald 2/11/2005 43744 #3 glow plug
270.25 Fitzgerald 2/15/2005 43744 EGR valve replace
0.00 Fitzgerald 2/28/2005 44227 glow plug harness
25.75 Fitzgerald 8/23/2005 53357 oil change
24.65 Fitzgerald 10/29/2005 58333 oil change
556.83 Autosport 11/3/2005 58656 60K, synth oil
169.14 Fitzgerald 5/13/2006 67699 headlight, oil change
246.18 Fitzgerald 5/23/2007 85444 Full inspect, oil, rethread
1476.97 Metrics 7/6/2007 90369 EMC, struts, timing belt, w. pump
EGR, oil, filters, 90K
250.95 Metrics 2/11/2008 95608 glow plugs and harness
oil change, needs brakes
235.05 Metrics 2/12/2008 95610 rear brakes and rotors
28.35 Metrics 1/14/2009 108304 oil change
52.97 Metrics 5/28/2009 110767 oil change
367.00 Metrics 4/1/2010 119176 oil, dimmer, antenna
273.22 Tires Plus 6/18/2011 129529 2 tires, alignment
500.50 Metrics 11/8/2011 135230 serp belt, roller, oil syntech
493.35 Fitzgerald 7/23/2012 144398 brake light bulbs thermostat
synth oil change
Recommend: mid muffler bracket
Tie rod ends
41.09 Fitzgerald 8/8/2012 144422 AC relay
223.46 Radial Tire 10/22/2012 144700 2 tires, alignment
-Josh
He's asking $7200. I think that might be a little high?Good solid TDI automatic Jetta wagon. Most of the 144.7K miles are highway - the original owner drove back and forth to Cape Cod from Annapolis. There are good repair records. I bought it recently and cleaned it up and put two new tires on and wiper blades - all it needed to pass inspection, which is current and can be used to register.
This is my first experience with a diesel. I like cars, and bought this one as a kind of experiment. I'm impressed and will probably buy a new one. Otherwise I'd just keep this forever.
So, take a look at the pictures and come on by if you're serious! I think it's fairly priced, and it's ready to go.
delivery 9/30/2002
synth oil change
Tie rod ends
-Josh
