OldVolks
- Joined
- Feb 7, 2004
- Location
- Orygun, USA
- TDI
- 1997,Jetta TDI, Stealth Black / 1996 Passat TDI, White to offset all that Blackness.
I am having a problem getting the Adaptations for the EGR and Fuel Quantity recalibrations to stick. I have some difficulty entering the numbers, but eventually get them changed and saved. When I go back in they look fine until I shut off the engine and restart it, then everything is back to the original settings /images/graemlins/mad.gif! I don't know if my VAG-COM setup is not working properly or what. Anybody else have any problems like this? I am going to try running it on a faster Laptop when I get a chance, just in case it is too slow or something. The one I am using is only a P233 W/32M and Win98, but nothing else on it but VAG-COM v303-1. This is the final tweaks I need after cleaning my intake (Boy was it plugged) and adding the PP520 nozzles. It has gone from a slug to a rocket just from these two things. I should have tried the clean intake before installing the nozzles, but I figured the old ones were getting worn out because of the excessive clatter. Sorry for the long post.....
