Mk4 golf asr light - new alternator esr light 10 minutes
henry0sp
london
mk4
Hi,
I have an issue with fault code 17911 - implausible load signal from the alternator, battery light appears with turn of key and disappears when car is started 14.5 volts at battery terminals on idle. However, ESR light appears exactly 10 mins after starting car regardless of engine on or not. Problem appears to be cabling but there is continuity from alternator.
thanks
