Old February 4th, 2015, 20:23   #1
nitrocharger
TDI(s): 14 Q5
Default Don't cut the wrong harness when replacing glow plug harness!
My glow plug harness was missing a few insulators so I started to replace it tonight. I found the harness plug conveniently located next to the battery. Or so I thought. I cut off the connector and old harness, put everything back together and started the car. I immediately got a battery light and eventually fault codes for glow plugs, all four of them. After I thought about what I've done and some research on the board, I found the correct harness and repaired the one I cut. I wanted to post this in case someone else does the same thing. Here's what I've learned;
1. The Germans should stick to mechanical design and stay away from electronics. The Japanese would never have the same two connectors in a car, much less in the same general area. Google "poka-yoke" and you'll see what I mean.
2. I should stick to mechanical repairs, not electrical
3. Always search the board first before even making the seemingly easiest repairs!
nitrocharger is offline   Reply With Quote
Old February 5th, 2015, 05:44   #2
jimbote
jimbote's Avatar
point 3. agree completely!! if you started with that the first two would have been moot points .... glad you got it sorted though and no permanent damage done ... as for germans using the same connectors in various places throughout the harness i kinda like it as it gives more options when looking for repair connectors
Replacing my glow plug wire harness sewerzuk VW MKIV-A4 TDIs (VE and PD) 4 July 1st, 2014 13:24
Help cut wrong plug replacing glow plug harness Kjames VW MKIV-A4 TDIs (VE and PD) 4 February 3rd, 2011 11:28
Replacing B4 glow plug harness Glennbo VW MKIII-A3/B4 TDIs 7 January 31st, 2008 09:38
Replacing glow plug harness - no space to splice (help) koabi VW MKIII-A3/B4 TDIs 15 November 27th, 2006 16:39
Replacing B4 Glow Plug Harness GMCpatrick VW MKIII-A3/B4 TDIs 6 December 16th, 2003 15:21
Page generated in 0.14074 seconds with 11 queries
[Output: 53.31 Kb. compressed to 49.28 Kb. by saving 4.03 Kb. (7.56%)]
