Michael Moore
I purchased a new set of wiper blades for my Golf at the dealer in Zurich today, and saw that VW has now incorporated a "change indication" into the wiper blade assembly.
The most common cause of poor wiper blade performance is not mechanical wear and abrasion of the blade surface, but degradation of the rubber material due to exposure to the sun, ozone in the atmosphere, and other chemicals. This is why new VW's ship from the factory with a set of small, disposable wiper blades installed on the windshield - the proper wiper blade assemblies are shipped in the trunk of the car, and are installed by the dealer as part of the pre delivery inspection process.
I'm not sure what exactly triggers the wear indicator on these blades, however, I suspect it is probably exposure to UV or exposure to ozone.
When these new blades are installed, the user peels a protective sticker off the side of the metal blade holder assembly, exposing the wear indicator. When the blades are new, the wear indicator is clear, therefore almost invisible. Over time, the wear indicator changes colour to yellow, indicating that blade replacement is needed. The wear indicator itself is nothing more than a very small sticker - about 4 mm in diameter - that is stuck on the metal frame.
I'm not sure if this part number is available in North America yet. The set of blades I bought were "standard" blades, meaning, not the new "Aero Wipers" discussed in this post - European Aero Wiper and Arm. I'll check next week and see if the new Aero Wipers come with this wear indicator also.
Composite Photo of Box containing Wiper Blades with Wear Indicator
[ November 09, 2002, 01:48: Message edited by: Michael Moore ]
