Old November 7th, 2018, 17:25   #61
ManicMechanic
All the boost piping has rubber couplings and the intercooler has rubber mounts so there should be minimal vibrations to the intercooler.
ManicMechanic is offline   Reply With Quote
Old November 8th, 2018, 04:59   #62
k_pt
k_pt's Avatar
TDI(s): VW MKIV TDI
Good, I've seen intercoolers craking because of all that metal on the pipping, which gives no absorption of the engine at all. Some rubber hoses help a lot.
Follow me on some mechanics works https://www.instagram.com/kptgarage1986/
k_pt is offline   Reply With Quote
Old November 8th, 2018, 08:43   #63
PickleRick
PickleRick's Avatar
Anyone besides me ever used the sewer connectors from lowes/home depot as connectors for intercooler piping?
Nothing says southern built like 200 bucks worth of stainless mandrel bends and sewer pipe connectors.
Weddings are basically funerals with cake
PickleRick is offline   Reply With Quote
Old November 14th, 2018, 12:23   #64
Hasenwerk
Hasenwerk's Avatar
I have, it sort of works. The issue is that it can't take the sustained heat. So the cold side of the intercooler it's never been an issue, the hot side, close to the turbo, it will distort and eventually fail.
It's great to use for a mock-up and run with it for a bit, but expect to remove it and replace with metal pipe after you are happy with the routing.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
'86 Suzuki Samurai TDI Swap number3114 TDI Conversions 45 November 22nd, 2015 08:27
Suzuki Samurai tdi50mpgnoob TDI Conversions 14 January 23rd, 2015 17:58
1988 suzuki samurai 1.6TD "debbie" swap CaTdi2002 TDI Conversions 1 July 30th, 2010 20:48
Diesel Suzuki Samurai GA_ZUK Private TDI Items for Sale/Wanted 8 March 7th, 2009 13:18
Suzuki Samurai gidb36 TDI Conversions 4 December 8th, 2005 15:40
Page generated in 0.13123 seconds with 12 queries
[Output: 66.36 Kb. compressed to 59.50 Kb. by saving 6.87 Kb. (10.35%)]
