Old November 8th, 2018, 05:57   #1
petee_c
Fuel Economy: 5.6ish L /100km golf.... just under 10L/100km q7
Default glow plug harness - plastic cracked.
I cracked the glow plug harness in a couple spots in my 12yr old 2006 Jetta TDI, when trying to remove it to diagnose a recent glow plug fault code.
It's not a high voltage application, I'm thinking of just giving it a coating of goop or something similiar to weatherproof the cracks...
Any suggestions?
Glow plug fault code is gone - it was a break in a wire from the ECU to the glow plug relay.
petee_c is offline   Reply With Quote
Old November 8th, 2018, 07:24   #2
Windjammer
TDI(s): MK4 & Mk5
If it were me, I'd just leave it as is until I replaced the harness.
00 Jetta TDI GLS Auto Black w/Beige leather, Phatbox
06 Jetta TDI Shadow Blue w/Beige Pkg 2 DSG W/NAV & Phatbox
06 Jetta TDI Blue Graphite w/Grey Pkg 2 DSG W/NAV & Ipod dock
06 Jetta TDI White w/Beige Pkg 2 DSG
06 Jetta TDI Black w/Beige Pkg 0 5MT
Windjammer is online now   Reply With Quote
Old November 8th, 2018, 10:17   #3
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
All of the insulation foam or whatever it is crumbled and fell off of the wires to my glow plugs. The car still runs great, so I am ignoring this condition. I have a new replacement engine wire harness, but am tired of working on cars at present and will only address issues once they become a problem.
sptsailing is offline   Reply With Quote
Old November 8th, 2018, 13:48   #4
crazyrunner33
crazyrunner33's Avatar
It's easy to make a new harness. It cost me around 15 dollars to do it on my '06, and that includes the beer. You'll need bullet connectors, 12 or 14 gauge wire, heat shrink and solder skills. I cut apart the whole harness and wrote down which color wires goes to which glow plug. The whole thing can be performed in a half hour or less. I used western union splices and grease as overkill to make sure there was a solid connection when splicing the harness.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Don't cut the wrong harness when replacing glow plug harness! nitrocharger VW MKIV-A4 TDIs (VE and PD) 1 February 5th, 2015 05:44
FS: ALH - new glow plug and glow plug harness kit Dunhamjr Private TDI Items for Sale/Wanted 2 September 19th, 2011 19:27
Help cut wrong plug replacing glow plug harness Kjames VW MKIV-A4 TDIs (VE and PD) 4 February 3rd, 2011 11:28
How to remove the B4 engine wiring harness connector? Glow plug harness content 914rrr VW MKIII-A3/B4 TDIs 11 March 4th, 2010 14:50
WTB: Glow plugs and glow plug wiring harness (01 Jetta) TDI_NC Private TDI Items for Sale/Wanted 2 January 5th, 2006 08:02
Page generated in 0.15405 seconds with 13 queries
[Output: 63.59 Kb. compressed to 56.96 Kb. by saving 6.63 Kb. (10.42%)]
