Hi there,
My issue is the following:
1. When I change P to Drive and I am on a little bit uneven surface, usually a car doesn't move until one pushes the gas pedal.
However, in my case, it moves slowly down. Nothing stops the car.
2. If I push the gas pedal, the car doesn't move while being on even surface. To move I need to push the gas pedal more until about 3000-4000 rpm and only then it moves slowly.
Once I removed the G38 sensor and it worked properly meaning I was able to start moving without additional acceleration. However, after a short time it didn't move again without acceleration. I replaced G38 by OEM one. However, it didn't help.
The ATF level is ok. ATF was bought at VW dealership.
Oil pressure is ok as well. I measured it.
There is no trouble code.
There's a lot of small particles like black paste in the transmission pan about 2-3 mm deep. The ATF has burned oil smell. I disassembled the oil filter and it had no metal/plastic pieces.
What would be your thoughts about the cause of such issues?
Thanks a lot for your help.
Regards,
Igor
Regards,
Igor
