Old July 24th, 2018, 21:04   #1
gayle
Default no check engine light or glow plug light on 2003 tdi golf 1.9
the lights never come on when I turn the key on, the car runs fine.
I am new and a bit lost on this site, I have a 2003 tdi 1.9 golf gl I have failed smog due to the fact the check engine light does not come on at all, the car runs great no issues also i do not see the the glow plug light either.
I live in Ventura,CA
I was told to go to the dealer and take all my keys and have a new cluster installed and they will match the keys to the cluster.
the car runs great just can not pass a smog as if the check engine light does not come on when the key is turned it is an automated fail.
Any help would be greatly appreciated.
gayle i
gayle is offline   Reply With Quote
Old July 24th, 2018, 21:26   #2
Vince Waldon
Vince Waldon's Avatar
Every once in a while we see a cluster where a previous owner has covered the Check Engine light with black electrician's tape... usually after deleting the EGR would be my guess.
Doesn't explain the missing glow plug light but might be worth a quick look just to confirm. Actually swapping a cluster is a bit of work, be nice if it was something simpler than than.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old July 24th, 2018, 21:54   #3
caideN
Not sure about VWs but I remember looking at an old Honda Civic for sale 10 years ago and the owner actually took out the bulb for the CEL. Shady...
caideN is offline   Reply With Quote
Old July 28th, 2018, 08:20   #4
TDI-WNC
Relay 109 caused that on my 2000 Jetta... but it wouldn't start, as it also controls the fuel shutoff solenoid on the injector pump.
TDI-WNC is offline   Reply With Quote
Old July 28th, 2018, 19:04   #5
wonneber
The light seems to be part of the control module. Does not look like it's replaceable.
Check fuses 11 15 and 10. They all provide power to the control module.
Long shot. Check if power is getting to pins 1 23 and 30 on the module.
Old July 29th, 2018, 16:24   #6
gayle
thank you so very much I will have those fuses checked.
what size fuse goes in the 32 slot on the driver side panel?
Old July 29th, 2018, 17:02   #7
gayle
what size fuses go in each?
11
15
10
Old July 29th, 2018, 17:05   #8
gayle
11
15
10
Old July 29th, 2018, 19:12   #9
wonneber
11
15
10
11 - 5 amp
15 - 5 amp
10 - 10 amp
Old August 10th, 2018, 21:26   #10
gayle
I have no idea what or where the mod is
Old August 10th, 2018, 21:27   #11
gayle
Mine runs fine.
Just need to fix it so I can have it pass the ca smog
Old August 10th, 2018, 21:28   #12
gayle
TDI(s): 2003 vw golf gls tdi
Old August 11th, 2018, 18:35   #13
wonneber
If I'm not mistaking its the part of the dash with the lights.
Old August 11th, 2018, 20:09   #14
gayle
Default update on cel still not working
The radio is an aftermarket radio and has a red wire in the fuse panel with and add a fuse connector and the radio works and then stops and that's that so there is a short and I think the radio is the culprit .
There is and add a fuse plugged into fuse #31 and it has two fuse piggy back on the plug this is for the radio what size fuse should be in the add a fuse?? Maybe the fuses in are wrong?
I am still going over the fuse to be sure they are all the correct ones.
any clues?
Still no cel spent $58.00 for them to do nothing have an appoint with the bureau of automobile to see whats up, in the mean time I have a 60 permit to drive it the tags are paid still had to pay the ca dmv.
Anyone near Ventura that has any knowledge about this please let me know.
thank all of you for all your replys.
I also have a straight exhaust if anyone is interested I am never going to use it.
Thanks again
Old August 11th, 2018, 20:13   #15
gayle
There is and add a fuse plugged into fuse #31 and it has two fuses piggy backed on the plug this is for the radio what size fuse should be in the add a fuse?? Maybe the fuses in are wrong?
TDI Mystery - Flashing Glow Plug Light & Check Engine Light shmeeshma TDI 101 5 May 28th, 2018 09:46
2013 Golf glow plug light/check engine light annamei VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 October 24th, 2014 17:16
Check Engine Light and Glow Plug (?) Light appearance in 2002 Jetta JGJetta TDI 101 4 September 15th, 2014 08:49
2003 TDI Golf. check engine light on, glow plug not firing, lack of acceleration Teresa TDI 101 15 August 21st, 2011 19:25
After battery replacement, check engine light on, glow plug light flashing ... redluv VW MKIV-A4 TDIs (VE and PD) 7 June 28th, 2011 10:59
Page generated in 0.19367 seconds with 11 queries
[Output: 118.75 Kb. compressed to 98.59 Kb. by saving 20.15 Kb. (16.97%)]
