Zheking
What up council?
AC quit at the end of last summer, i just dealt with it since it was the end, but anyone around here knows you can't go a full summer without AC around here. They sure didn't make this compressor easy to get to, and the AC system complicated. Never had to deal with a FCM in my Z or all this other electrical stuff, as it just uses a clutch fan, compressor, and a pressure switch. that system was way easier to diagnose and fix.
My compressor is not kicking on.
I've checked a few things.
1. checked low side pressure. was good. around 40 lbs (so I'm not dealing with a leak, thank goodness.)
2. checked fans. both come on with key on 'on' and ac 'on'. (however, they do sound like i need to clean the brushes.)
3. checked the pressure switch (via replacement)
Is there anything else I need to check top side before moving to the bottom / compressor area? If not, what's next?
From what I've gathered / my experience working on cars, my next step is to put key and everything back to 'on' and check for voltage coming to the compressor from the FCM? (it won't be 12v though since the FCM lowers it from what i've read)? Then if voltage is there, plug that back in to the compressor and check resistance on the coil, it should be 1/2 ohm? Then what?
Or if I'm way off, let me know the next steps? Thanks.
