Old October 4th, 2014, 21:55   #1
annamei
Exclamation 2013 Golf glow plug light/check engine light
2013 Golf TDI 4-door, 20,825 miles /purchased Sept. 2012 has had all of its regular checkups & maintenance.
This is my first brand new car and first diesel so forgive my ignorance on the proper terms/engine knowledge. I've owned 2 used GTIs that I loved but dumped heaps of cash into to keep them running.
Today while driving about 2 miles after starting my car the glow plug light(?) started flashing and it felt like I lost power. I got to a safe place about 500 feet after, pulled over, turned off the car and started it again it seemed ok for a minute but then it started flashing again then the check engine light came on, I turned it off and it wouldn't turn back on (made a clicking noise). I had my infant daughter in the car and it was 100 degrees out today so I was pretty upset after calling VW roadside assistance and being told a tow truck was at least an hour away when I was in the middle of a busy populated area of town.
When I got to the dealer they asked what happened, I explained and they said "welp, we're really busy today, service isn't open tomorrow so we probably won't get to it until monday" and tried to send me on my way. I asked for a loaner and they said ok, when I asked if I was going to have to pay for the loaner they said depending on what is wrong with my car yes - if its the battery or something. I realize this isn't their fault but it smelled like an ashtray and was filthy. My daughter & I both have asthma and cannot be around cigarette smoke so I drove it back to swap it out and they were pretty rude. I'm getting off track here but is this normal behavior from the dealer? Am I just being overly sensitive? When I took it in for regularly schedule maintenance I never got this kind of treatment.
I LOVE this car and on one hand I'm glad that this happened while its still under warranty but I'm worried, am I going to have another VW that costs more to repair then a new car payment? Is it time to think about trading it in?
annamei is offline   Reply With Quote
Old October 4th, 2014, 21:57   #2
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: 130 MPGe
Normal behavior from a dealer? Unfortunately we see poor dealer service too often.
You won't have to pay for the loaner because there is obviously something wrong with your car. A flashing glow plug light indicates a major fault.
Old October 5th, 2014, 03:43   #3
Tdijarhead
Let's hope it's just the Saturday crew that didn't really want to be there that was being less than " kind". Even if it is a battery, and it is not, we are talking about a very new car. I would just assume they will cover everything including the loaner even if it is a battery that should last a minimum of 4-5 years.
Tdijarhead is offline   Reply With Quote
Old October 5th, 2014, 04:37   #4
Matt927
Matt927's Avatar
TDI(s): several
Did the motor crank normally but just not turn over?
Matt927 is offline   Reply With Quote
Old October 5th, 2014, 06:39   #5
annamei
After the second time the light came on & CEL came on it when I tried turn it over the dash lights, A/C, radio, etc came on but the engine just made a whine then a loud click. I was pretty distracted with a crying baby so I don't have much more detail then that, I didn't keep trying because I didn't want to flood the engine or do more damage. The tow truck driver kind of treated me like a dumb girl and said it was probably the battery and tried to turn it over too but it made the same loud whine then click noise. Living in the desert I've had to replace batteries every 2 years even if you pull maintenance on them. If it was just the battery I would have had a friend jump me but it didn't sound like that to me. Does that make sense?
Also while I was sitting waiting I had ample time to read my entire warranty handbook and it says the battery is only covered for 2 years/22000 miles and I am just over 1 month over 2 years.
Old October 5th, 2014, 11:52   #6
Matt927
Matt927's Avatar
TDI(s): several
I unfortunately do not think it was a battery issue. You don't happen to to know any of the codes pulled?
Old October 5th, 2014, 11:55   #7
Good Ol' Boy
VeeDubTDI's Avatar
Loud whine then click sounds like the starter trying to turn over, but not having enough power to do so.
Old October 5th, 2014, 11:59   #8
annamei
No I don't, as far as I know it hasn't even been looked at yet. Will they give the codes to me on a report about the repair or do I need to ask for them?
Old October 5th, 2014, 14:02   #9
Matt927
Matt927's Avatar
TDI(s): several
They should give them to you on the work order. When they call you ask them, I'd be interested to know.
Hopefully it is an easy and quick fix.
Old October 6th, 2014, 09:42   #10
annamei
Ok I just spoke with the dealer and they said there were no codes? This sounds incorrect to me - wouldn't the CEL register some codes? Anyhow he said its the High Pressure Fuel Pump - the bearings failed, they need to get the parts from VW and they're keeping my car until at least Thursday.
Old October 6th, 2014, 10:01   #11
Matt927
Matt927's Avatar
TDI(s): several
That is what I thought. Read up on VW HPFP failure. Tons of info here.
Go onto NHTSA's website and report your failure there to add to the ongoing investigation.
Also add your failure here and you will see you are not alone.
http://forums.tdiclub.com/showthread.php?t=299854
Old October 6th, 2014, 10:19   #12
annamei
Thanks for the info Matt927. I just reported to NHTSA, does that actually help with recalls?
Old October 6th, 2014, 10:54   #13
Matt927
Matt927's Avatar
TDI(s): several
Probably not, until someone is hurt. Their investigation and engineering analysis has been ongoing for years but still not closed.
VWOA also recently issued a memo to its service departments to retain and ship back all failed HPFP units for further analysis.
Do you remember where you purchased fuel last? You might want to contact the station and see if anyone else has reported problems with the last diesel load.
I am going to assume you never used a diesel fuel additive?
Old October 6th, 2014, 11:08   #14
annamei
I know exactly where I purchased fuel from last because I was on my way out of town for a business trip and stopped at a station I don't normally go to.
On 09/22/2014 at a Shell station just off the freeway in an upscale shopping center:
http://www.phoenixgasprices.com/Shel...163/index.aspx
I always save my receipts so that I can check my fuel economy but I put them in my glove box so it is in my car at the dealer right now. Will they be able to tell from the date & time which batch my fuel came from? And I guess the bigger question, will they care?
I have never used an additive. The reason I joined this site is because I was interested in using alternative diesel but after reading about it I realized that I don't have the time, energy or room to store and deal with WVO.
Old October 6th, 2014, 12:47   #15
Matt927
Matt927's Avatar
TDI(s): several
WVO won't work in a CR TDI regardless. Some swear by fuel additives like Optilube to help improve the lubricity of our questionable US diesel supply among other things.
Stations are responsible for the fuel they sell and have a guarantee on it, chances are slim but you never know.
Ask your dealer if they took a fuel sample.
Check Engine Light and Glow Plug (?) Light appearance in 2002 Jetta JGJetta TDI 101 4 September 15th, 2014 08:49
Check engine light-glow plug light & limp mode Slothbar VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 17 November 30th, 2013 10:30
After battery replacement, check engine light on, glow plug light flashing ... redluv VW MKIV-A4 TDIs (VE and PD) 7 June 28th, 2011 10:59
Low oil pressure, check engine light, glow plug light??? thomps33 VW MKV-A5 Golf/Jettas 2 March 21st, 2011 18:01
HELP! Check engine light (solid) glow plug light (blinking) no symptoms TDI Steve VW MKIV-A4 TDIs (VE and PD) 16 December 18th, 2001 09:50
Page generated in 0.16943 seconds with 11 queries
[Output: 126.41 Kb. compressed to 105.64 Kb. by saving 20.77 Kb. (16.43%)]
