I noticed I was leaking oil towards the back of the engine and after investigating I found that the tube connecting to the top left of the engine, is loose.
So I found that a small part of what I think is the throttle body (top rear left) is broken and for this reason, the pipe isn't hooking up perfectly.
When I unplug the pipe going into the engine, I noticed an good amount of oil accumulation.
The oil leaks out because the pipe is lose, and with the air pressure... it gets pushed out I guess.
I will be fixing the air leak myself, however is it normal to have quite a bit of oil in there, which certainly gets ingested in the engine ?.
Since I discovered this I have been monitoring my engine oil level and it looks all good. Has not dropped at all in about 1000km.
Boost gauge appears to run normal. 10-15 when driving normally.
Not smoking unless I floor it, which I almost never do. (The smoking is normal given it's got modified injectors and a custom malone tune)
Ill keep my eye on it, just wondering if it's something I should be concerned about.
Car detail are the following.
2007 Jetta, swapped 2006 TDI BRM
PD140 Turbo (About 6000km on it only)
