Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old May 13th, 2019, 10:00   #1
20062015VWman
Default My 2015 Golf check engine light keeps turning on.
Hello everybody. I'm not a first time owner of a TDI but have run into a little problem with the '15 Golf TDI I have owned for the past two years. Since the end of March 2019 the check engine light comes on and then after a couple of days turns off and then turns back on again after another two days. My tech says it could be the electrical harness for the engine, he hooked it up to his computer and it gave off seven different codes indicating seven different problems. After a couple of hours of keeping it in the shop he hooked it up again and it gave an array of other codes indicating a different problem. He says he's never seen this before, he says the electrical harness may need to be replaced but I'm looking at $1300 for the part and labor. And he doesn't want to do the job if after spending the money the problem persists. Has anyone else had this problem? The car runs like a champ so I have no idea what could be the issue.
Last edited by 20062015VWman; May 13th, 2019 at 10:01. Reason: added a bit of text.
20062015VWman is offline   Reply With Quote
Old May 13th, 2019, 10:05   #2
oilhammer's Avatar
Fuel Economy: fantastic
We have no idea either, since the only clue you have are the DTCs which you have not shared.
Is this car not under the warranty extension?
www.cardocautomotive.com
Old May 13th, 2019, 10:09   #3
20062015VWman
I'll have to get the papers with the codes off my tech. He still has them. I'll have to check and see I was just wondering if anyone had a similar issue.
Took 2015 GSW TDI in for Check Engine light... TMccord12 VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 11 December 26th, 2018 10:03
no check engine light or glow plug light on 2003 tdi golf 1.9 gayle VW MKIV-A4 TDIs (VE and PD) 17 August 12th, 2018 00:38
2013 Golf glow plug light/check engine light annamei VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 33 October 24th, 2014 17:16
2000 Golf TDI Airbag light & P3130 check engine light agrusco VW MKIV-A4 TDIs (VE and PD) 2 June 18th, 2014 12:53
Turning off the check engine light C-Dog TDI 101 7 August 24th, 2009 12:17
Page generated in 0.08607 seconds with 12 queries
[Output: 58.69 Kb. compressed to 53.20 Kb. by saving 5.49 Kb. (9.36%)]
