kennster
- Joined
- Nov 13, 2006
- Location
- Toronto
- TDI
- 2002 Jetta TDI(RIP), 2011 Jetta TDI Highline(RIP),2015 Passat TDI Highline
I have 99600kms on my 2015 TDI Passat..with 100000 warranty...i did an auto scan...and found some faults....im a dope..is there anyone here that can let me know...if any of these faults are under warranty.....should i park it...till i get them fixed??..or am i just dreaming...lol...thanks....heres my log....
Friday,26,April,2019,01:15:30:01859
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: XXXXXXXXXXXXXXXXXXX License Plate: KEN
Mileage: 99600km-61888mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCV7A31FC074290 Mileage: 99600km-61888miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 016 D HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9466
Revision: 8AH20---
Coding: 011D0012832410089000
Shop #: WSC 93246 999 00000
ASAM Dataset: EV_ECM20TDI01104L997016D 004002
ROD: EV_ECM20TDI01104L997016D.rod
VCID: 34311F1C6EBB1B974A5-8060
1 Fault Found:
23010 - Exhaust Gas Recirculation System
P240F 00 [096] - Response too Slow
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4518
Revision: 05653104 Serial number: 00001412170596
Coding: 0000020
Shop #: WSC 09003 957 00200
VCID: 2517F258D9E1721FCDB-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492900FEA30D03ED92190042A0100012
VCID: 04518FDC7E1B6B17BA5-8050
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0356927675
Coding: 130C0C
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_A02_VW31.rod
VCID: 372B28107FCDF08F6F7-8062
1 Fault Found:
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
B1172 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Mileage: 99234 km
Date: 2019.04.21
Time: 04:49:09
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 561 907 044 AR HW: 561 907 044 AR
Component: Climatronic H03 0808
Revision: 00001K01
Coding: 0050019012
ASAM Dataset: EV_ACClimaBHBVW411 A01001
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 678BB8506FEDA00F3F7-8032
1 Fault Found:
9473393 - Motor for Right Temperature Flap
B108D 71 [009] - Actuator stuck
Freeze Frame:
Fault Priority: 2
Fault Frequency: 56
Reset counter: 83
Mileage: 93157 km
Date: 2019.01.26
Time: 05:07:30
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+ 122 0174
Revision: BL122001
Coding: EF200E3B8C2D2AD408880201360085C800F1A08645A005B064806000BC70
VCID: 78A9EB2C32D33FF7A6D-802C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 171214 05 54 0403
Coding: 0E300A
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD053194
Coding: 00004D38
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72BDD904542F55A7989-8026
Seat occupied recognition:
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 6940000Y150001AGHE0V
Coding: 303047
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME6B242C4BZZZ2
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME54412B4BZZZ-
Crash sensor for side airbag: rear: driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME67630B34ZZZT
Crash sensor for side airbag: rear: passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME5F714F33ZZZ0
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME25603B33ZZZR
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME30473B33ZZZT
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL 016 0162
Revision: FF010042 Serial number: 20141208300178
Coding: 000A140000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EA5FD34107701C7EC1-802A
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-8LP H07 0023
Serial number: 00000000000001014142
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 870 E HW: 561 920 870 E
Component: KOMBI H05 0813
Serial number: 00000000000000
Coding: 331E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04723
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 1B63D4A0E325B4EF6BF-804E
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 09021503000464
Coding: 461000
VCID: 005983CC6A0377379ED-8054
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 93563 km
Time Indication: 0
Date: 2019.02.02
Time: 14:16:56
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0813
Serial number:
Coding: 000007
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC1647CFF9D67209-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000350213004
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3039130C9AA327B72ED-8064
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0183
Revision: AA000000 Serial number: 00000133072100
Coding: 00581B0000000000000021010100202020202120202020
VCID: 221DE944C4CF8527A89-8076
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0009290258
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C61D7BCE62BB3D7625-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630150210160633
Coding: 800000
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
Shop #: WSC 01357 011 00200
VCID: 392F2E284559E6FF993-806C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0034829
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 2809FB6CA2736F77F6D-807C
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FBBD070479D784F777-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011418203281
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 009 0005
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0009292334
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D67DAB8FD31BADF95B-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631150209213021
Coding: 800000
Address 56: Radio Labels:
VCID: 55F78298CC01229F9DB-FFFE
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666830594
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 323D190494AF15A7589-8066
3 Faults Found:
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 201
Mileage: 93563 km
Date: 2019.02.02
Time: 14:16:52
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 93563 km
Date: 2019.02.02
Time: 22:50:14
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 93563 km
Date: 2019.02.02
Time: 22:50:14
End----------(Elapsed Time: 01:21, VBatt start/end: 14.2V/14.2V)-----------
www.Ross-Tech.com
52 56 62 72 77
Revision: 8AH20---
1 Fault Found:
Coding: 0000020
Revision: 00H46001
Coding: 130C0C
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 120
Mileage: 99234 km
Date: 2019.04.21
Time: 04:49:09
Revision: 00001K01
Coding: 0050019012
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 56
Reset counter: 83
Mileage: 93157 km
Date: 2019.01.26
Time: 05:07:30
Revision: BL122001
Coding: 0E300A
Coding: 00004D38
Coding: 303047
Coding: 000A140000
Coding: E20000
Coding: 331E01
Coding: 461000
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 201
Mileage: 93563 km
Time Indication: 0
Date: 2019.02.02
Time: 14:16:56
Serial number:
Coding: 000007
Cannot be reached
Cannot be reached
Coding: 0405FD
Slave Driver:
Coding: 800000
Revision: 00H22000
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
ROD: EV_UHVUMI.rod
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 201
Mileage: 93563 km
Date: 2019.02.02
Time: 14:16:52
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 93563 km
Date: 2019.02.02
Time: 22:50:14
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 202
Mileage: 93563 km
Date: 2019.02.02
Time: 22:50:14
