Strider17
- Joined
- Apr 5, 2016
- Location
- Hamilton, Ontario, Canada
- TDI
- Beetle(sold) MK4 Golf TDI(sold) Mk4 Jetta TDI(parted out) MK4 Golf GTI w/ALH swap (built then parted out) 2015 Passat TDI Highline (current)
2015 Passat TDI SEL
So there is no air coming out of my center dash vents. A little air is coming out of the middle ones.
I also ripped out and tested the 2 servo motors under the steering wheel. They move and dont seem to be the problem. Not sure which servo motor is the bad one or where its located. Any input?
VCDS showed this in the HVAC module:
Motor for Front Air Distribution Flap
B1091 71 (009) - Actuator Stuck
Confirmed - Tested Since Memory Clear
