AV8RLEO
Hi all,
I've been reading through the threads on thermostat inssues, A/C issues, and cooling fan issues.
I have a 2003 TDi Jetta with about 207,000 miles on it. Thought I had replace the thermostat when I did the high mileage timing belt kit (ID parts) about 40,000 miles ago. When I reviewed the receipt for the repair it turns out I did not.
Here's what has been going on.
Over the last week the temperature was running just slightly high (1 tick past TDC on the temp gauge). I noticed that when it would run up there the A/C would cut out.
When I got home late one night I popped the hood to remind myself to double check all fluids the next morning. When I opened the hood I had what I thought was power steering fluid EVERYWHERE, so new problem.
Turns out my A/C compressor had fried and puked oil everywhere tinted green due to the R134A and dye I had in the system. Had the A/C compressor and power steering pump (also leaking) replaced. Antifreeze right where it is supposed to be, no soot or other contaminants in the bottle. Forgot to troubleshoot T-Stat (stupid I know).
Today I was driving home from work and noticed the A/C cutting out again and T-gauge running that same one tick high. Never during any of this did any lights SES or otherwise illuminate.
No milkyness to the oil.
Stopped at my uncles shop when I got it home and hooked it up to the computer. Coolant temp was 248 degrees. Sh!t. So, definitely ordering a new thermostat and Coolant temp sensor. Guessing mine is stuck partially closed...
So here are my questions...
1) Wahler T-Stat for $19 or OEM for $40
2) At what temp does the A/C cut out to cut load to the engine?
3) In testing my cooling fans both turned on when I turned on the A/C inside the car, however neither was running as it was sitting there idling with coolant temps at 248 degrees. That doesn't seem normal to me, is it?
Thanks in advance everyone.
Note to anyone reading this who questions whether the temp gauge is accurate... IT MOST DEFINITELY IS NOT! "mathematically I should have been somewhere around 217 degrees, not 248 based on the "gauge..."
