Jeece
Car: Jetta Mk4 99.5 TDI ALH. Mods: mikroTuning chip (Alligator?) and 0.205 nozzles. 330000 km (200000 miles).
Symptoms: Last week, while "cleaning my intake" on a highway on-ramp (with a moderate up-grade), I was at about 3000 RPM in 4th and still accelerating firmly, ready to shift. Suddenly, no more power. Car went limp, barely accelerating. According to my ScanGauge unit, boost was 5-6 PSI at the most and it showed. Acceleration felt worse than a stock TDI. No CEL.
Rebooted the car, and it was fine (though I was afraid to really punch it). Now the limp mode has come back a few times during the week, even without hard acceleration (as I said, I was easy on the go-pedal): sometimes, while cruising steady, if I wanted to simply adjust my speed, even with a slight press on the accelerator I felt a lack of power. This went on until I turned off the car. But it never occured *during* an acceleration (maybe at the begining so I can't notice the change).
So I met a local guy with good knowledge in TDIs to analyze this.
- We test drove the car, hard, and it boosted fine. Of course.
- No codes showed up in VagCom.
- Actuator moves allright.
- Turbo vanes too (but we didn't open the turbo)
- Intake manifold was dirty, but not clogged. Anyways it was on my to-do list.
- He tested a vacuum (N75? I think) and no bad results.
We noticed the EGR has spat some oil on top of the valve cover, dunno if it could be related. But it was fresh/wet oil, and no sign or prior contamination on the otherwise clean cover. Though there seemed to be an older dirty spray pattern on the cowl area behind the EGR, but it's not fresh.
I'm now looking at this thread for more ideas: Diagnosing and Fixing Limp mode for A4 1.9TDI ... but we've already ruled out many causes.
I don't think it could be the MAF, since it's an intermittent trouble. MAFs are either fine or totally borked, and performance simply degrade over time, without remission, right? Anyhow I'll test it just in case.
According to the ScanGauge, I have a spike at 20-21 PSI when accelerating, which (as I now know) is too much for the *gasp* stock turbo. But it has been this way since I've had the chip, and never went in limp mode before. Sure thing I'll keep a eye on the boost from now on.
Any further input is appreciated.
Thanks all!
edit: Air filter is somewhat dirty and due for change, but still have a lot of breathing area. The snow screen is *gone*, so it isn't clogged.
Thanks all!
