TWSTDVW
Great. Are there any other troubleshooting methods that I should consider?
Vacuum hose!TWSTDVW said:Great. Are there any other troubleshooting methods that I should consider?
In the process of replacing them all, I found that one was disconnected. It was the line that goes from the "Y" to the check valve. I had a similar issue a few years ago. I guess this is happening on it's own.whitedog said:So you tested them and found the bad one? Did you replace all of them?
The melting point of brass is only 1650 F (900C) degrees or so. While it would be attractive for its lubricating properties, aren't you concerned about it softening or melting and deforming?vw_steve said:ive been doing lots of these. i even install brass shim stock under the lower three spacers. that way it gives it a little more clearance for the vanes. i have done dozens and none are noticing any lack of power what so ever. i started to do that because some customers were coming back a year later with the same problem. since the shim stock i have not had one come back.(knock on wood). the hardest part of the job is to separate the two halves. i use an acet. torch to heat the steel up. but im sure a propane torch would work.(a little longer but should work).
You are on your way to healing your car, then you need to work on preventative care. I think Drivbiwire has talked about how to keep it from happening again. It's all in how you drive it.Gringo said:Hi everyone. Guess what, I am now getting limp mode quite often and I started troubleshooting yesterday.... N75, VNT and vacuum lines are all good. I disconnected the VNT from the lever on the turbo and it moves about 3/4 inch to 1 inch freely EXECPT sometimes it sticks/grabs and then I have to apply quite a bit of force to move it again.
All this to say that all bolts on the exhaust manifold/turbo assembly have been soaking in PB blaster since yesterday... I will give the VNT repair/cleaning procedure a try.
Did anyone have good success after the cleanup? Are limp mode taking care of?
Will the cleanup last for a long time or is it just a matter of time before the problem shows up again?
UserID "TDIjetta99" is in Port Jervis, NY...DinoPjetrovic said:does anyone know anyone that could do this around northern NJ?
