No turbo boost.
Excellent data drivebywire which I suspect I may have to utilize.
My 02 1.9TDI Passat 130ps has very limited and intermittent turbo boost.
Ran fault code test;
17664 engine temp sensor
17964 turbo pressure control
17552 air flow meter.
To date I have replace both N75 valves, air mass meter, fuel filter, air filter, checked all vacuum hoses, checked intercooler for blockages, checked operation of VNT actuator, (this moves freely by hand and also when rpm is increased).
Fault occurred for the first time when climbing steep incline under 3/4 throttle, since then no real turbo boost has been available and limp mode is incurred with wide throttle settings or when under load.
Any help with this will be greatly appreciated. I am new to this site which I think is excellent.
Many thanks
tiffyh UK
