Camplate - Plunger - Nozzle Combination Diagrams
Napalm00
Bay Area
200tdi
Turbo sounds rather small for a 2.8l engine and 2 bar. Id go for a decent hybrid with 48 to 50mm comp inducer and a 51/49 mm turbine. Or a s200v if space is available
engine only makes 105 hp stock and is low revving, i need full boost low. hence the small unit. stock is a TB02
redline is 4k but actual driving you never go over 3.4k
currently i can make 30 psi at 2800 rpm its great .
majesty78
Austria/ Europe
Skoda Superb 3T5 CFFB
30psi so late in rpm range with 2.8L displacement and such "small" turbo + ballbearing?
Are you sure the VNT setup is correct?
