Lug_Nut
TDIClub Enthusiast, Pre-Forum Veteran Member
- Joined
- Jun 20, 1998
- Location
- Sterling, Massachusetts. USA
- TDI
- idi: 1988 Bolens DGT1700H, the other oil burner: 1967 Saab Sonett II two stroke
regarding compression: VW specification is 360 to 450 psi new. At 1/4 million miles of obvious less-than-ideal maintenance I don't think that 10% under new minimum is too bad. VW specification for maximum difference is 70 psi. I'm at 15. I have other worries.
It revs up just fine with no intake or exhaust manifold. I began bolting things back on the head. The exhaust manifold and turbo were attached and plumbed to the oil supply and drain. The hot side outlet (down pipe) and the cold side inlet and outlet ports are still open. It revs up to redline.
I added the intake manifold, the EGR cooler, the EGR valve, and connected the piping between these. I did not connect the vacuum operator line. The low limit rpm condition returned.
I know.....I said one-by-one but then I did three at once. Tomorrow I'll take off the EGR items and try with just the exhaust manifold and turbo, and the bare intake, and go from there, one-by-one.
No really, this time I mean it.
