Air to water cooler.... why don't i see a lot?
Bush Hopper
Vendor , w/Business number
Thunder Bay and in the Bush
97 Eurovan, 2001 Jetta and a few other
I am not whining about anything. I am just making it clear, unless you over budget and those who budgeted 200-400 dollars are in for a big surprise for the ATW. The car I showed in the picture has over $18,000 in modifications. I am sure those who budgeted 200-400 dollars will be whining about there car being in pieces while they are waiting for missing parts, or they will be whining in 2 months why isn't their ATW working properly. I don't care anymore, I will stop wasting my time trying to help OP with proper planing.
Diesel-Benz, final point I would like to make for my personal satisfaction :D . Map sensor bunk cost over $35. Obviously you did not mention that fact in your shopping list. This simple example proved that none of you who provided a Shopping list considered 100% everything required. Your budget failed already. Did you just forget? Maybe take my advice and over budget. You would be waiting 2-5 days before you get the map sensor bunk, unless your order over night shipping, and then your into even more cost. Good luck next time.
Intercooler: $185 (and that was $85 more expensive than if I went with the more common design)
Pump: Free, already on the car.
Air couplers: $30
Hoses: $10
Radiator: Free, already on the car.
Intake manifold: $15 for the pipe
Total cost of my system: $238
ChippedNotBroken
Pocono\'s, NYC
Jetta A4 1999.5 Green
I think we've all been there, and paid the price. But I have also seen where innovative people here on the site have figured out cheaper, better ways to get things done. It is often trial an error getting there, something that I am sure you know all too well. Trial and error costs money, and I haven't heard too many people crying about how much they under budgeted there projects, they either pony up, stretch it out or abandon it as a bad idea.
Pointing out things that might be needed in someones plans is useful, telling them they are wasting their time or that it is going to cost too much, well I already wrote what I think about that.
I love your car BTW.
Bush Hopper
I think you miss understood me. I never said they are wasting their time. I am actually one of the few in this thread that support ATW setups. I think you have me confused with others who said ATW is not good way to go.
ChippedNotBroken
Pocono\'s, NYC
There is no doubt that your system is beautiful, and that you are a proponent of the technology. It will be interesting to see how many and what results are obtained from the less elaborate and potentially less expensive setups.
TDIJetta99
Port Jervis, New York, USA
03... Faster than yours =]
I'm happy with my air-air setup that actually did cost me $300 after considering saw blades, the extra on the electric bill to run the air compressor and sawzall, etc.. The first one I did, which was on my car, I hacked up a few things quite extensively, but the few I did after that look stock after the bumper cover is on.. My 03 Jetta has a Golf nose on it, and I'm going to put a FMIC on and I will be certain to post pictures of the finished product for Kasper to see.. It will look completely stock, minimal bumper support modification, and will have fog lights in the small grilles.. I'll be putting it together over the winter along with a few other serious mods..
Alex22
Western CT
2014 Jetta
Ummm, what is that for in an intercooler system? I do agree with you that the setup that Diesel-Benz made for his own personal vehicle wouldn't be acceptable to build for just about any paying customer. I'm not sure how cheap I am going to be on the build components (hoses, fittings and such).
As for the cost of materials/electricity, I can do just about whatever I want to do after hours at the shop. Its one of the perks of working there, I also get deals on parts. Back purged welds? seriously, this is an intercooler build. Even if I did back purge the welds there would only be a few and I would be able to rent a bottle and I get deals on the gas so those costs would be minimal.
The appeal of this system to me is having a short pressure tube runs and only having to run a few wires and some water lines.
Are we just disputing the cost of using an air to water intercooler?
sardo_67
CT
2015 Golf SEL 6spd
Flying Kasper can you post more info on your ATW cooler? I would like to know which one you went with along with which pump you run.
Stealth TDI
Pre-Forum Veteran Member
Newport News, VA
2017 GTI APR Stage 3 (395 hp/376 lb-ft)
Hello,
Only reason why I would go water to air is to preserve the stock front end on the golf. FMIC does not fit on a GOLF. Requires a lot of work, and it will never look stock.
Those who think a Golf is tight should check out a MKIII. I've seen some good looking FMIC installs in MKIIIs. But I'm 99% certain a FMIC cannot be installed in one without cutting the rebar:
I think I've read that some needed to move the radiator back an inch, too. I'm just not sure an FMIC is worth the structural integrity of the car; nor the sacrfice in rigidity in the front of a car used for autocross.
I've considered A/W for a LONG time and have had my eyes on the FrozenBoost kits. I've also considered dual SMICs (I even have a used SMIC on hand for test fitting). But I also understand my greatest cost on either project will revolve around paying someone to fab up the aluminum piping. The A/W piping should be less than dual SMICs, especially if I put the AWIC in the stock location. :)
But all of this is just brain fodder. I'm in no rush to make a move. I have a lot on my plate already. I'll be watching this topic. Please post your results and costs, even if overrun.
Good Luck,
Scott
dieseleux
Théoricien -TDIClub Contributor
Pas assez loin pour vider ma tank!
Jetta TDI 02
Finaly a buy a AWIC kit...
I pay 499$ for a KIT + 3x silicone adaptor tube + 180degree tube + 2x tube with 3 port 3/8 (before and after AWIC, pressure and temp verification, last hole is for injection option!).
My plan is put 12x12 rad on driver side (like see on picture), AWIC dehind intake and use oem IC with water to make more heat dissipation capacity and small reservoire.
With PD130 intake and GTB1756VK install on my fresh ALH rebuilt, i think this setup make very good power and look oem.
Dieseleux
NoJoke
I wish this thread went on a more informative road as I might use a air-water-air setup on the intermediate part of the compound setup we're after.
Now on Diesel-Benz's defense...yes defense; he might be a miserable man (which loves company):D. He is very informative at the same time.
I'm envious of the mechanical standalone control setup he has on his car. Now it may not be very refined but it works. He has started many threads on the MB forum (superturbodiesel.com) that I reference from time to time.
Diesel Benz likes to be controversial, not the approach I would take. Bottom line is we're all after the same thing "MORE POWER" and everyone's opinion counts .
sardo_67
CT
2015 Golf SEL 6spd
Don't worry, I'm ordering parts now and I'll let you guys know how it goes.
sardo_67
CT
2015 Golf SEL 6spd
Come on, I'm trying to keep this about something interesting.... Or at least usefull
Bush Hopper
Ok, Well when your picking a core, pick the biggest one you can fit. The bigger the better. I would recommend trying to fit the biggest Radiator for the water, with a decent size res. Use the bosch water pump from the SC mustang. The rest is logical, avoid sharp bends, make it as direct as possible. and do a nice job with wiring the water pump. Hook it up to the oil pressure sensor.
Stealth TDI
Newport News, VA
Kasper,
...and do a nice job with wiring the water pump. Hook it up to the oil pressure sensor.
I've considered powering it via N109 along with my lift pump or maybe using a Hobbs switch to allow boost to trigger it. But why the oil pressure sensor? Do you know how the Mustang does it?
Scott
Bush Hopper
Kasper,
Scott
Hobbs meters run of the oil pressure sensor. Why? Because a Hobbs meter will not count time unless you have oil pressure. Why? Well RPM= more oil pressure. Unless you have rpm, no need for the Hobbs meter to count time on the engine, not enough tear and wear, ( if we are talking about the same hobbs meter ).
You set it up so that unless your engine has a load, there is no need for the water pump to run. You will need a relay I believe to make the oil pressure sensor activate the water pump. You can wire it up any way you like. Not a big deal if you do it differently then I did. MY fans and water pump do not run at start up until oil pressure builds, preventing my battery draining during start up or before start up. If your oil pressure is low, most likely the temperature of the oil should be low, so your turbo should be running fairly cool, and it most likely is not making boost at Idle rpm. My method is quite easy solution.
sardo_67
CT
2015 Golf SEL 6spd
interesting, so when should the pump come on and i would guess to just put a temp gauge in the radiator to turn the fan on at a certain tremp?
i would like to set mine up like that but have an actual "on" switch as well so if i'm doing a dyno run or for what ever reason would like the water circulating i can.
Stealth TDI
Newport News, VA
FK,
Thanks for the explanation. A Hobbs switch, if I understand correctly, can accept an air pressure input and can be set to activate at a certain pressure. Therefore, I could likely set it to energize the pump when the intake manifold is above 5-psi... or perhaps 2-psi if I want it to run when the car is in motion.
Scott
Diesel_Benz
Banned
Denver, Colorado
Mercedes
That is false. The water pump needs to be running all the time to keep the water as close to ambient as possible.
Wrong as well. The Bosch water pump pulls less than 1amp.
The pump can run all night long without draining your battery.
Actually, its vastly overcomplicated.
Listen to somebody with actual experience building a quality system; me.
Hook the pump up to an ignition switched power source and put a 1amp fuse inline. Done.
If you really want to over complicate the system then add a 130*f temperature switch to the outlet of the intercooler's radiator to activate the radiator fan.
Why do people continue to listen to Flying Kasper? Its very clear he is a troll with no intelligible information on the subject.
I receive my kit!
Now that is a decent system. That design core is far more efficient than the cheaper wedge style, just plumb the cold water to the air outlet side with hot water exiting the air inlet side. Where do you plan on installing the intercooler?
ChippedNotBroken
Pocono\'s, NYC
Mmmmmm.
kooyajerms
grocery getter
Pomona, Southern California
97 B4V (mine), 11 x5 35d (hers) 04 V10 (that one you want), 2014 Q7 (mom's) 74 Shasta 1400
Well at least he doesn't try to hide it. Even spent enough time to update his profile for us.
