AARodriguez Corp.
TDIClub Enthusiast, Vendor , w/Business number
I'll post pics tomorrow, car is at home
300,000 miles
The Good:
-Runs great
-Cam changed at 250,000 miles
-Radio works good
-New A/C Compressor
-Includes Malone Stage 1.5 tune
Known Issues
-Car interior is rough in my opinion but I've ridden in other TDIs that are much worse.
-Heat does not work well
-Car has blend door problem
-Tiptronic 09A tranny needs to warm up for 5 minutes before the car will drive forward, reverse is never a problem, needs a new solenoid.
-Shifter handle is broken, needs to be replaced or you can use as is if you pull on interior plastic lever
-wiring connector to the cluster was damaged, causing RMPs to not reflect accurately
-a relay under the dash needs to be replaced, you can hear it clicking intermittently while driving.
300,000 miles
The Good:
-Runs great
-Radio works good
-New A/C Compressor
Known Issues
