H Helge Member Joined Sep 24, 2006 Location Norway TDI None Dec 16, 2007 #1 I suspect that the engine in my wife´s 1995 Audi A6 140hp tdi is rather worn. Are there anyone selling rebuild/overhaul kit for this engine?
D Drivbiwire Zehntes Jahr der Veteran Joined Oct 13, 1998 Location Boise, Idaho TDI 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI Dec 16, 2007 #2 The engine isn't an "R5" since this designation was not used until the 5 cylinder PD engine used in the T'Reg. VW does not sell "rebuild Kits" for the motors. Your motor is no longer available from the latest VW parts list. DB
DERV-NERD Veteran Member Joined Oct 10, 2007 Location UK TDI PASSAT PD130 Dec 16, 2007 #3 The same engine is fitted to the volvo v70/s70 (engine code D5252T) untill 2001. If this is any help.
W wrenchman30 Veteran Member Joined Oct 1, 2007 Location arkansas TDI 2005.5 gray 2006 dark blue Dec 16, 2007 #4 have a manometer test ran to verify its worn out. you might try sealed power, trw for a engine kit.
D Drivbiwire Zehntes Jahr der Veteran Joined Oct 13, 1998 Location Boise, Idaho TDI 2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI Dec 16, 2007 #5 What is the compression readings of the motor? This is the only way to check the engine condition in regards to HSDI type diesels. DB
