Odd clutch problem...
Mark_K
Gainesville, GA
03 Jetta TDI Wagon
I was driving along and as I depressed the clutch pedal, there was a slight pop felt/heard. Afterwards, the clutch would not disengage.
I've replaced the slave cylinder, replaced the master cylinder under the dashboard and even removed the transmission and checked the clutch with no obvious signs of failure. No broken fingers and when they were depressed, all returned to place.
So, I'm at a loss! My only thought that when I installed the new master cylinder, I managed to depress the clutch pedal all the way down but without the "bump stop" in place. Maybe damaged a seal in the process(?) or could it be the clutch?
JETaah
Vendor , w/Business number
mi 48836
Which clutch/flywheel do you have in place? Is this stock? Would you know if it is not?
