DIESELMAN3500
- Joined
- Mar 2, 2008
- Location
- Norther New Jersey
- TDI
- 2000 Jetta TDI,2006 vw tdi jetta,2003 vw beetle,2003 vw golf
hey guys, got a question for you.
I have a 2000 jetta with 202k on her, its a 5 speed, no mods just picked the car up and did the injectors, new timing belt etc. Car turns out has low compression on number 3 cylinder, i did 3 compresson tests and came up with close (within 10 psi) each time. did hot cold etc. 1= 450psi, 2= 450psi, 3= 390psi, 4=455psi, this number 3 is making the car smoke and shake and mis at idle and it used to throw a code for cylinder 3 misfire but after playing with friends com and adjust timing, new injector nozzles pop tested its still here and car is bad when its cold.
I checked the turbo and tubes for oil and none
I have pressurized cylinder 3 and hear no noise out exhaust or intake (but didnt listen to the crank case to see if rings leaking.)
I have not checked to see if intake is clogged, i did clean egr and antishudder valve.
I did not throw oil in chamber to see if number rises but should probably do that.
Ok throw some ideas at me, if need be can i pull head ( get resurfaced, new gasket etc) and bore out #3 and put oversized rings in it to fix the problem if its the rings. Should i drive the car and see if a ring is stuck, car was not taken car of by previous who only had it for 4k and front end collision bu tjust hood and grill damaged and radiator.
Is it possible a ring is stuck, what oil would you throw down cylinder?
where is best place to buy good, cheap, piston, rings and stuff.
thanks in advance
John
thanks in advance
John
