Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Central Canada
Central Canada Local discussions for those between the Rockies and the Great Lakes (Alberta to Manitoba).
Old December 1st, 2016, 18:51   #76
Lurker92
Hey all, I'm in Airdrie. I've got a VCDS and I can hack your cluster for you/extract skc's on 2005 and older cars. I've also got the timing belt tools for PD's, will help out too if you need.
One thing I don't have is a dial bore gauge, anyone got one I can borrow? Just pulled an engine from pick n pull and I'll be taking the head off soon and need to measure the bores.
Lurker92 is offline   Reply With Quote
Old December 6th, 2016, 10:40   #77
Geobmx4life
Geobmx4life's Avatar
Fuel Economy: 2005Golf TDI 50mpg...best 60
Default Good t see another AB guy
I don't have the tool, but a local club Eurodrivers.ca forum someone might....I'm a moderator there and would love to see more TDI guys out.
2005 Golf TDI, VNT 17, Malone stage 4, Spec stage 2 clutch, .658 5th gear, FMIC, Ventectomy, NewSouth gauges, BuzzKen 2.5 turbo back exhaust, Evolution Skidplate, Helix OEM Reps retrofitted with Morimoto Bixenon mini's, FK coils, 18in Serrons. Frostheater
Geobmx4life is offline   Reply With Quote
Old December 6th, 2016, 23:16   #78
Lurker92
Thanks, I was able to borrow one from work but I'll pop by the site anyway .
Old December 21st, 2017, 11:39   #79
kayn1n3
TDI(s): 2014 Jetta
First post. If this necro-post is out of line my apologies.
Bought a '14 Jetta TDI with the DSG in June of this year. Located in Westlock County. I LOVE it. You could not pry it out of my hands.
I had no idea there were forums dedicated to the TDI. Going to be doing a ton of reading here because Norden keeps emailing me that the Gen 1 emissions update has not been done on my car yet. After some light reading it appears that I may not want to get it done yet.
kayn1n3 is offline   Reply With Quote
Old December 26th, 2017, 19:02   #80
martiniwg
Hi kayn1n3,
I'm glad to see that you're enjoying your new car!
Lot's of reading about it indeed.
Cheers!
martiniwg is offline   Reply With Quote
Old January 26th, 2018, 04:54   #81
Jamielewis
Edmonton here! Old thread but if anyone is looking I have all the tools to do the timing belt on a 2006 vw jetta tdi brm. As well as the cam. I also have vcds if you need.
Jamielewis is offline   Reply With Quote
Old January 26th, 2018, 06:45   #82
Alchemist
TDI(s): '04 ALH Golf
I am just getting my shop set up in Lethbridge. Hoist and compressor are up and running, heat is on and parts organization is well under way. VCDS is always on and ready to use.
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old January 26th, 2018, 21:32   #83
GEFP
Alchemist. What's your address for your shop in Lethbridge? I might just drop in sometime.
I live between The Hat and Lethbridge (Hays). For us it's about an hour either way. I also have a VCDS.
GEFP is offline   Reply With Quote
Old February 3rd, 2018, 18:11   #84
vincej
Calgary here. Got an engine light for engine misfire whatever that is about. Can anybody do a VCDS read? Thanks. Will have to get that fixed before they do the fix for me. Or maybe I will turn it in. 155k kms.
Just saw the link to eurodrivers.ca so now will look for the March get-together.
vincej is offline   Reply With Quote
Old March 29th, 2018, 20:37   #85
TheGambler
Edmonton Here! Just picked up my 15 TDI a couple months ago. Lovin every minute of it.
TheGambler is offline   Reply With Quote
Old May 10th, 2018, 17:12   #86
killerpassat
calgary here, does any one have the timing belt tools to change the timing belt here in calgary?
killerpassat is offline   Reply With Quote
What chip/flash are people using on this forum. a3vw TDI Power Enhancements 3 August 14th, 2007 14:55
Alberta TDI forum members spicy_red Central Canada 79 July 11th, 2006 22:05
Alberta TDI forum members spicy_red TDI 101 0 September 12th, 2004 18:50
People, Time to Help Out a Forum Brother dieseldorf VW MKIII-A3/B4 TDIs 79 October 22nd, 2003 18:39
Another forum where people discuss this stuff. christi TDI (Diesel) Emissions 3 August 3rd, 2000 03:00
Page generated in 0.14839 seconds with 10 queries
[Output: 101.06 Kb. compressed to 85.54 Kb. by saving 15.52 Kb. (15.35%)]
