why not use the hella actuator to ajust vgt... im asking because turbine wheel is a godd size Turbine 60mm exd 70mm Ind 12 blade and Compressor 60mm Ind 86mm exd 7 blade is also good i think. now its the turbine housing size im worried about. i have a chance to buy one so i would put it on my bmw m57n e46 compact. just wondering if it would work well. turbine is same spec as a borg warner s300v and that works pretty well on a 3000cc 6 cylinder
