riebs
Overheating Again [Resolved]
So... my Jetta's overheating again. I thought I fixed this a month ago, but apparently not.
Here's what happened today:
I'm confused because I read the Overheating Diagnosis thread in TDI 101. It points me towards a bad Water Pump.
However:
I got a tow home.
I'm confused as to what I should start replacing first.
Would it be possible for a Metal Graf WP to fail this soon? How do you inspect it without removal?
As a side note: I've had a heater core leak since I bought the car (4 years of pancake smell) but it's never caused any major problems. Could it have played a roll in this? I just read the VWVortex thread on replacement and I'm praying it's not to blame.
PS: I have Sam Adams Octoberfest for any Richmond TDIers out there who might be able to show me a thing or two.
UPDATE:
I ended up replacing
Note: I had a gradual coolant leak for about 1-2 months prior to the cooling system crapping on itself. It never dripped coolant on the ground, so I could never pinpoint the leak. In all my prodding and poking over the last few days however I think I found it.
The metal coolant pipe that connects to the top of the coolant expansion tank has both of its nipples broken off. The nipple closest to the driver side began spraying coolant everywhere after all the replacement parts were in. I ended up cutting the leak off the pipe and shortening the pipes overall length as a quick fix. I'm assuming that the nipple broke or bent itself and creaked a pinhole leak, which was not visible because of it's location.
Also: No heat was coming out of the dash. After the parts were in and the car was at operating temp, I turned the heat on and got nothing. I drove it 2 miles to test everything and turned the heat on again and got this:
After the steamy coolant cleared, I had great heat coming from my vents. Any ideas what could've caused that?
- Drove 2.5 hours with no problems, 190 degrees, AC on.
- Stopped for 45 min
- 30 min in to drive home, AC got warm and temp shot up
- No heat from vents
- Lots of pressure in coolant tank
- Lower radiator hose not hot
- Only small fan comes on when AC is on (never saw the driver's side on even with temps above 230)
However:
- Installed metal Graf Water Pump (DieselGeek Deluxe TB kit) less than 20k miles ago.
- Installed OEM thermostat 2 weeks ago.
- Installed new thermostat housing 5k miles ago.
- Installed radiator fan assembly this summer.
I got a tow home.
UPDATE:
- the fan assembly
- thermostat housing (and bolts)
- thermostat gasket
- temp senso
- and the coolant expansion tank.
