Power FIST for the WIN
UPDATE Nov 8, 2016: Power fist struts quickly lost lifting power, I do not recommend! They will only hold the hatch up after they are fully extended at this point. I am a little dissappointed and embarrassed to report.
This spring I replaced the hatch, and this summer I finally re-installed the inside cover including a repair of the "access hole":
Soon after replacing the cover the hatch seemed to only stay up if it was pushed all the way up, and it was getting worse. I should have probably started shopping for new hatch gas spring strut shock things sooner. Instead I waited till the one on the left let go completely. That is when I really had to start looking:
I called my local NAPA and they quoted $38 which seemed reasonable for a quality part and I would have picked one up but they didn't have any in stock. The friendly parts person there went on to say they don't bother stocking them because "Canadian Tire has them way cheaper." Okie dokie, thanks for the tip.
I called my local Canadian Tire Auto Parts person and right away they were like "Volkswagen? We problem don't have em." And then, an awkward amount of time later, "Nope I don't even have a listing for your car." Well, that is typical for Canadian Tire.
Now I know I could ordered these online but I had one more local place I could check. Princess Auto:
Other hardware stores probably have these too but Princess Auto had a great selection: all you have to do is bring the old part, hold it up the ones on the shelf and find the ones you need, and they were only $11.99 each! I bought two and they literally installed in seconds.
My hatch looks like new, and now opens like new too! It will hold itself up anywhere from half way to fully open. It took a few cycles to "get used to" the new feel. Its delightful.
I've used Power Fist brand tools for years but this is the first actual Power Fist brand part installed on the car, other than windshield wipers, and maybe hitch balls, but those didn't have the name printed on them in this intriguing way:
If only every repair was this cheap, easy, and satisfying!
It sure is nice to have all the trim back in the hatch and have it feeling just like new. Just one more picture:
