mogly
Lately with the cooler weather my car has been starting and sort of chugging a bit. The GP light was coming on maybe 1-2 seconds so I decided it was time to do some GPs. Let me add that this is my first tdi but I've had several IDIs and the GP are much more accessible Anyhow, I had one with no continuity through it and it was on the flywheel side. The long of the short I put my socket on it and the buggar just spins in the hole. While the other three were removed with nominal pressure. I tried getting a little pry bar underneath while I turned the plug with my socket but it's STUCK, unfortunately now it can be turned by hand and has a little wobble to it. Bummer.
So my car is just about due for it's VR clutch upgrade so I've decided to haul the engine out and do some scheduled maintenance ie: intake cleaning and some seepy gasket replacement.
Here's a couple of questions I'd appreciate someone enlightening me on. Is it easier to drop the subframe out of these passats ('96 Variant) or shall I lift the engine out by it's lonesome? It seems rather tight on the passenger side more so than my previous A3 IIRC. Also, I'm assuming that I can take my head into a machine shop and have them remove the stuck GP and have them weld and cut new threads for my GP? I hope that someone else can vouch for this procedure. One last thing I should be replacing my head studs with new units, correct?
If you've made it this far through my novel- thank you. Any suggestions/incouragement is appreciated.
Cheers.
Rob
Cheers.
Rob
