electrical issues affecting radio
Thunder Chicken
Sioux Lookout, Ontario
2012 Golf Wagon
SO the radio (RCD310?) quit working in our '12 golf wagon. It would come on intermittantly however. I checked every fise in the car and all appear to be good. (Thanks VW for not putting the fuse diagram in the owners manual)
After some seaches and googling, it looked like quite a few others had issues with the radio quitting. So I ordered an aftermarket unit.
Installed today, and wouldnt ya know, it wont work, or does very intermittantly as well.
A scan with VCDS shows this:
Thursday,03,January,2019,19:40:36:06919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 18.9.0.4
Data version: 20181017 DS296.0
www.Ross-Tech.com
VIN: 3VWML7AJ1CM695743 License Plate: NAT
Mileage: 216710km-134657mi Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 56 62 72
VIN: 3VWML7AJ1CM695743 Mileage: 216710km-134657miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 D HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H14--- Serial number:
Coding: 0350072
Shop #: WSC 74291 008 00000
VCID: 2F672114BE064B3272-807A
1 Fault Found:
049489 - No Communications with Airbag Control Module
U0151 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 216714 km
Time Indication: 0
Date: 2013.05.26
Time: 18:58:04
Freeze Frame:
RPM: 0 /min
Voltage: 12.16 V
Temperature: -2.7∞C
Temperature: 32.4∞C
Bin. Bits: 00000000
Torque: 219.0 Nm
Temperature: 16.2∞C
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492B00FF881206E8921C0042300000
Shop #: WSC 00066 123 12345
VCID: 7DFBCB5CE4EA69A2B0-8028
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000004002
Shop #: WSC 00066 000 00118
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 0005B2A89B18044ADB-8054
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 N HW: 5K0 937 086 N
Component: BCM PQ35 M 021 0064
Revision: BJ021001
Coding: 2F380E1F802D3EC4000000C1700085EC49010086535D0560648020200040
VCID: 3F877154AE66BBB2E2-806A
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 22041 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA1WLGS
Coding: 00003134
Shop #: WSC 00066 000 00000
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3F877154A666BBB2E2-806A
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2626436AZZZW
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4563456BZZZ
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME2C123F2BZZZT
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME3B06422BZZZL
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME775C682BZZZY
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME0712632BZZZ9
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 AT HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KKH0001P
Coding: 1080140000
Shop #: WSC 00066 000 00186
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 0201B8A09514165ACD-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 862 A HW: 5K0 920 862 A
Component: KOMBI H03 0605
Serial number: 00000000000000
Coding: 380700
Shop #: WSC 00066 123 00118
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 2C5D36184710302A57-8078
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 23041201290529
Coding: 352002
VCID: 3D7B0B5CA46AA9A2F0-8068
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 19
Mileage: 216714 km
Time Indication: 0
Date: 2013.05.26
Time: 19:37:06
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0605
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1F0008D64EE1A65-803E
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0004385083
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BBFA5C4523E8792EE-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 008 1509
Serial number: 00000006595795
Coding: 000490
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 37771974465683F22A-8062
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 050B0500
VCID: 6FE7E114BE860B3232-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0004300464
Coding: 000CB4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CBDA6D8573080AAE7-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 008 1509
Serial number: 00000006535970
Coding: 000490
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:41)--------------------------
SO a problem with an Airbag control module, and a Databus for Infotainment, and the radio.
Any chance there is one loose connector somewhere? ive wiggled all the wires and bundles I can easily reach. up near the clutch pedal theres a bunch of relays and all looks normal there.
Several months ago I had the windshield replaced.....
Its not uncommon for rodent damage in these parts but I dont see any obvious sign, even in where the wiper motor is. Next step is to remove that plastic cover around the wiper arms and look see whats in there.
The battery is original, but still does start the car well, even in the recent -20, -30 temps we recently had, so im not convinced its a low voltage problem.
Any insight on where to check would be helpful!
Thanks!
Thunder Chicken
2012 Golf Wagon
so now thats its not -20 out and my fingers can stand tinkering.....
Reset all the fault codes.
Only one returning is from the CAN Gateway.....
Coding: 352002
1 Fault Found:
All I want is to have a radio!!!! I bought some sort of Android unit (ATOTO A6) to hook up thinking the stock unit was pooched.
Is there a way to wire a radio in these cars with an add-a-fuse and bypass the canbus?
The radio's harness has a +12v acc that goes to the canbus adapter, and a hot +12 that would go to the vehicle harness.
What I really should do is figure out why this is not working to begin with.....
sootchucker
Colorado
2015 Golf
this is a known issue that will likely require replacement. I had the same problem back in the day... along with many others!
edit- sorry, I did not see that you already replaced it...
PRY4SNO
Edmonton, AB
2013 Touareg Execline
I had the same thing except mine shut off and never turned on again. I'm certain it's the headunit, which will make it fun removing the CDs.
Odd thing is that I had a similar fault with the ABS module shortly before the radio went out and never occurred again. Not too long afterwards my ECM went bad, luckily VW warrantied it with the emissions recall. Not sure if this helps, but thought it odd we both had a radio go out and a subsequent ABS module issue.
Thunder Chicken
2012 Golf Wagon
after finding this thread:http://www.forums.tdiclub.com/showthread.php?t=400355&page=2
I tried a few more things.....the pushing of the power button does nothing.
I checked the red/yellow wires for voltage.....there is a fluctuating from 5-10 volts on both of the red/yellow wires. I can only assume they should be at 12v. The car battery is fine and load tests ok.
So now....where does the power come from......
PRY4SNO, the Airbag fault was from me pulling fuses while the car was powered on.....oops. after cleaning the fault codes from the modules none have came back but the databus one.....
BarryT82
Charleston, WV
‘12 JSW TDI
If the radio can’t be reached then it’s either a fuse or the radio is dead. If it has the RCD-310 I’d replace it with an RCD-510, RNS-510, or RNS-315 and add a backup camera. You can get each of those models with the factory backup camera input on the rear. I have a few of them if you need to buy one.
Thunder Chicken
2012 Golf Wagon
So I found a hit all the time fuse and added an add-a-fuse and ran a hot wire to the radio. It worked. Sort of. It would reset, always show the clock, asked for the security code once, but would not power on all the time. Seemed likes it’s pooched. However, I’m still getting the databus infotainment code from vcds.
I had this Atoto radio here, stuck it in and tada it works. Vcds sees the radio (there is a canbus adapter on it) but still got that other error.
Barry, id have considered a factory unit but there are no wires in my car for a back up camera or Nav. So I’d have to add it all and that ain’t happening.
