Old December 26th, 2018, 14:15   #481
Mike in Anchorage
Mike in Anchorage's Avatar
Originally Posted by sprstu View Post
2015 GSW 6spd 64K miles, MANY small annoyances
Investigating a cold temp clicking in the front suspension, probably sway bar end link but annoying this early in its life
Investigating rear wheel bearing noise at slow speed around corners (think roundabout)
Investigating clunking from rear suspension on speed bumps
Clutch slipping under heavy load in 4-5-6th gear. Must always shift down to get above 3K rpm to avoid slipping.
Driver window auto up-down 50% functioning
Radio forgets station upon start up and goes back to static 50% of the time
Tire pressure monitor system thinks tires are low, investigating reveals the system is wrong
Torn 2 outer CV boots, driver side, car is OEM height
Back up camera is 50% function, many times just black screen
*As much as I hate to recommend it, have you taken it to the dealer, in particular with respect to clutch slippage?
*Window regulator should also be covered under warranty.
*TPMS - you can reset. Have you done that at a low enough temp to keep it from alarming again?
*Radio - no idea. Do you use bluetooth for your phone? Does it function the same whether or not your phone is BT enabled?
Best wishes for the new year.
~ I'm selfish, impatient and a little insecure. I make mistakes, I am out of control and at times hard to handle. But if you can't handle me at my worst, then you sure as hell don't deserve me at my best. Marilyn Monroe
2015 Tornado Red Golf TDI Sportwagen SE, new on 2 SEP 2017, DSG, big sunroof. Lovin it!
Mike in Anchorage is offline   Reply With Quote
Old December 26th, 2018, 14:31   #482
Nuje
Fuel Economy: 1200km/tank (Mk4); 750km/tank (Mk7)
Radio going back to static is the "87.7 radio station bug". Talked about more than once here.
Torn CV boots - wow! Not sure what you're driving over, but that does seem bad.
Clutch slippage - that's not good. Take that in for sure.
Back-up camera in my car is the best of probably 20 different cars I've driven in - only time it doesn't work is if I put it in R, then go out of R to another gear, then back into R again.
Nuje is offline   Reply With Quote
Old December 27th, 2018, 07:00   #483
MiniAustinMini
I have been rather disappointed with the MK7 quality overall. My mk6 JSW with triple the miles was a more solid driving vehicle. I like the Ea288 engine more but the car itself feels inferior overall. Perhaps are I replace parts with non-OE pieces they will be superior quality but I have my doubts.
Does this happen to be the red one purchased from Hall VW this summer/fall? I was very interested, but when they started showing me pictures of it at the junkyard it came from... Its sad how some of these buybacks were treated.
Many of your gremlins could be cause by water damage/dry rot. My '15 GSW 6spd with 33k has only a squeak behind the dash to complain about. (had the peeling shift boot trim replaced the week after I bought it)
Best of luck to you. Do you have any kind of buy-back guarantee on it?
MiniAustinMini is offline   Reply With Quote
Old December 27th, 2018, 15:29   #484
adjat84th
adjat84th's Avatar
Fuel Economy: ~50 in mixed driving
It would not surprise me if the clutch delay valve (restrictor) that's built into the bleeder unit could cause a slipping clutch after some miles.
FWIW, my MK7 has 75k miles and no crazy issues that weren't self inflicted.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, Sachs SRE w/DMF, Fluidampr
adjat84th is offline   Reply With Quote
Old December 29th, 2018, 09:05   #485
sprstu
Fuel Economy: average:42 best:48
It is a platinum grey originally from Michigan that was purchased in Minneapolis in sept 2017. It sat for a little while, 2 months, while it was in limbo being fixed but the CarFax shows a pretty quick turn around from VW buying it, fixing it and then selling it at auction.
None my issue are life ending, just very annoying.
81 Caddy 1.6TD
2015 Platimun GSW 6spd, post fix Kerma Tune
sprstu is offline   Reply With Quote
Old January 2nd, 2019, 05:54   #486
740GLE
I find I need to hold the window switch way longer than I should to initiate the auto up/down feature (1-2 seconds, where our previous MK5 and NMS it's instant), almost like there's lag in the canbus for it to register.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Buying a 2006 2.5l TDI (R5) - Looking for advice on common issues? rsd VW Touareg TDIs 2 June 23rd, 2014 15:37
CV Boot Issues Common? JBell VW MKVI-A6 Jetta Sedan (~ 2011+) 5 February 15th, 2014 02:26
Common issues at 250k miles bmccrea TDI 101 9 November 6th, 2009 13:22
Lag issues common arnd 90000? What 2 tll dealr? ChadMad VW MKIV-A4 TDIs (VE and PD) 1 May 5th, 2005 19:14
(Early) New Years resolutions for my B4 TDIMeister VW MKIII-A3/B4 TDIs 4 December 23rd, 2002 07:29
Page generated in 0.13922 seconds with 12 queries
[Output: 83.04 Kb. compressed to 73.61 Kb. by saving 9.43 Kb. (11.35%)]
