Old September 16th, 2018, 15:04   #1
DCLXVI
Default BEW Swap into pickup/O2 question
I am currently attempting my first engine swap and I am using everything on the engine the way it came out of the mk4 Jetta minus the intake flaps. I already had Malone tune out the immobilizer and add dynamic egr and dynamic idle.My question is what would happen if I delete the O2 sensor? Also what would be the effect of removing the MAF?
DCLXVI is offline   Reply With Quote
Old September 17th, 2018, 12:49   #2
Owain@malonetuning
Neither maf or O2 delete will stop the engine from running but it won't be ideal since it will default to MAP sensor for inlet reading and won't have a reference for smoke output. Running the EGR dynamically also requires the maf.
The components can just be deleted in an updated tune too, there are a few other codes to remove for swap applications, feel free to shoot us an email. Should be fine to get the motor running in a swap though and then dial it in later.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
WTB: Downpipe for BEW with O2 sensor jodu Private TDI Items for Sale/Wanted 3 April 14th, 2016 19:37
bew o2 sensor code what happens if ignored mittzlepick VW MKIV-A4 TDIs (VE and PD) 0 August 22nd, 2014 16:17
05' jetta wagen BEW 5 speed swap question embryriddledude TDI Power Enhancements 5 May 20th, 2014 14:51
WTB: BEW O2 Sensor witchcraftz Private TDI Items for Sale/Wanted 2 January 27th, 2012 16:52
WTB Bad BEW O2 sensor TDIinTexas Private TDI Items for Sale/Wanted 2 July 23rd, 2009 09:00
Page generated in 0.11034 seconds with 12 queries
[Output: 52.70 Kb. compressed to 48.72 Kb. by saving 3.98 Kb. (7.55%)]
