Saturday,23,February,2019,14:20:55:18922
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: 3VWJL7AJ7AM043614 License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWJL7AJ7AM043614 Mileage: 313130km-194569miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 K HW: 03L 906 022 TS
Component: R4 2.0l TDI G001AG 9983
Revision: 12H02--- Serial number:
Coding: 0350078
Shop #: WSC 64755 001 1048576
VCID: 3635241D4443E317741-8062
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 052 HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 8938
Revision: 04844002 Serial number: 00000908050057
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 51FF7781CDEDA42F413-8004
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 114B400C492600FD881102E5921D0042B100
VCID: 005982C55A079DA79ED-8054
1 Fault Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 14
Reset counter: 141
Mileage: 312538 km
Time Indication: 0
Date: 2013.07.06
Time: 08:51:16
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 93
Count: 51520
Count: 0
Count: 0
Count: 0
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 J HW: 3C8 907 336 J
Component: Climatic H13 0203
Revision: 00008001
Coding: 0000000000
Shop #: WSC 00066 000 00187
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 34311E155EBFF1074A5-8060
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 A HW: 5K0 937 084 A
Component: BCM PQ35 B 008 6019
Revision: BG008001
Coding: 6D200B1A902F3EE4000000054000000001000086500085605C8020000000
VCID: 30391205AA27CD272ED-8064
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 01100 21 0501
Coding: 009795
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 09 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM019PGZ
Coding: 0012345
VCID: 6E85CC7D7C939BD77C1-803A
Subsystem 1 - Serial number: 6332MSME4942510B7
Subsystem 2 - Serial number: 6342MSME4942456DJ
Subsystem 3 - Serial number: 6351HSME1D237477B
Subsystem 4 - Serial number: 6361HSME1D230C4AD
Subsystem 5 - Serial number: 63727SME000F182E0
Subsystem 6 - Serial number: 63827SME00125201F
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0001031
VCID: 025D88CD580B8FB7889-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5M0 920 860 C HW: 5M0 920 860 C
Component: KOMBI H08 0020
Revision: V0008011 Serial number:
Coding: 370700
Shop #: WSC 00066 000 00150
ASAM Dataset: EV_KombiUDSMM9RM10 A04010
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 2E050C7DB093DBD73C1-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 200809F1000014
Coding: ED807F06000202001002
VCID: 6695B45D54635397041-8032
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 159
Mileage: 303488 km
Time Indication: 0
Date: 2013.02.16
Time: 22:15:20
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H08 0020
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
ROD: EV_ImmoUDSMM9RM10_VW12.rod
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1525
Revision: 72009005 Serial number: 00000875498903
Coding: 0001205
VCID: 6FBBD1797B9992DF777-803A
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 254
Reset counter: 101
Mileage: 303488 km
Time Indication: 0
Date: 2013.02.16
Time: 22:15:18
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 2F3B1179BB19D2DF377-807A
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 18
Reset counter: 141
Mileage: 313128 km
Time Indication: 0
Date: 2013.07.15
Time: 18:44:10
Freeze Frame:
Voltage: 13.88 V
DU
Temperature: 22.0°C
RPM: 1498 /min
Speed: 47.0 km/h
Speed: 47.0 km/h
Count: 0
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1525
Revision: 72009005 Serial number: 09060408394701
Coding: 0001204
VCID: 70B9D20566A78D276ED-8024
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000004284784
Coding: 0001168
VCID: 76B5E41D04C3A317B41-8022
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000004245110
Coding: 0001168
VCID: 77ABE91903C9DA1FAF7-8022
End----------(Elapsed Time: 01:11, VBatt start/end: 12.0V/12.0V)-----------
