RV9Factory
Hi Folks,
Background:
I've got an '06 Jetta TDI. A couple of years ago I put in a Darkside turbo with their braided oil line and a Stage 4 Malone tune.
Last July ('17) my camshaft started going so I replaced it and the rockers with a Colt cam from Kerma.
Not too long after that my turbo went out with a sheared turbine shaft. It started making a very mechanical-sounding whining noise and then just died altogether. It had less than 20k miles on it.
I was able to buy a replacement cartridge from Darkside and installed it in October, but shortly after that the car went down flashing PRNDS. That took forever to get sorted and I just got the car running last weekend.
The new turbo cartridge has right around 1200 miles on it but something is making a noise that makes me slightly nervous. It is a faint whistle and sounds very much like the alternator noise you might get in a stereo system. It varies with RPM and happens whether I am driving or in Park. It starts at about 1300 RPM.
I have removed the accessory belt and the noise didn't go away.
All o-rings in the intake system were replaced during the turbo installation.
Here is a video - you can hear it pretty clearly.
https://youtu.be/vBQCdfnSK5w
Any ideas what this could be? I sure as hell hope it's not turbo bushings starting to fail because like I said, this thing only has about 1200 miles on it.
Thanks!
Background:
Thanks!
